Rob, Did you ever get this figured out? I'm having the same problem.
Thanks much,
Chris
Hi -
I'm a product engineer on the Maps for Office dev team. Just saw your question and passed it along to some of the other folks on the team that are more familiar with Portal. According to them, it sounds like "the Portal this user is connecting to is not configured with a dedicated hosted server. As I do not see that in his description. Also we show these messages when we could not identify a hosted server configured in the Portal."
You can find more information about configuring hosting servers at the following help link:
http://resources.arcgis.com/en/help/main/10.2/index.html#//017s0000006n000000
Let me know if this helps!
Scott
Hi Scott,
I really appreciate your response. This is helpful. So basically much of
the functionality for ESRI Maps for office requires a hosted server on
Portal for ArcGIS or using tokens to publish services to ArcGIS Online?
Rob
That's correct, you'll need a hosted server to use most of the Maps for Office functionality.
We have the same problem here. We do not use portal but instead just ArcGIS Online.
Did the privileges recently change? I am trying to follow the chart found on Configure ArcGIS Maps for Office—ArcGIS Maps for Office | ArcGIS to determine what I need to use. We want our users to geocode using our internal geocoders - and not one from Esri. This is the default geocoder for my profile on ArcGIS Online.
Any suggestions appreciated,
Alison
Hi. I have the exact same issue here. I had an older version of Maps for Office on my old laptop. Working just fine with no such warnings. Lately it has ben reminding me of an update pending, which I´ve ben ignorring since I was about to get a new laptop. Now when I finally got the new PC and installed Maps for Office with the update to latest version it gives me this warning on application startup. I'm connecting to my organization ArcGIS Online account (not an Enterprise Portal) in order to use our own basemaps and address locator.
What I do not understand is why "configuration of Portal " is mentioned when it is ArcGIS Online that I am connected to?
