How many feature we can load to arcgis javascript 4.6 api view? how we can increase feature numbers? I have a feature service that has 120000 features. I have problem to load and view this map.
The SceneView rendering is already done via webgl. If you have a lot of data that you want to visualize in 3D your best solution is to use Scene Layers.
Do you know about next arcgis java script release? Does esri add webgl-rendering for 3d Scene view?
- The new webgl rendering referenced above is only for 2D MapViews; see webgl-rendering
- If you have a lot of 3D data, then please use Pro to publish your data as Scene Layers; that is what they're designed for.
ok
Does esri has program to solve this issue on the next release? how we can ask esri to solve problem?
If you can help more, I don't forget...
Migrate to what?...
So let me try an explain. I provided the documentaton and a sample that shows how to achieve what you asked. I personally have not need for the 3D environment and definitely have no need to display 120,000 features in a featurelayer. If I even had a need to display that many features I would always use a MapImageLayer and let the Server handle the load instead of expecting a clients browser to handle it.
There are time on GeoNet that I will not answer a question because of several reasons:
Hi Robert
I guess you are too busy or don't like to answer my questions. If you don't answer questions in this blog, there is not any person to answer. This mean we have to migrate
I add this before js load(2 weeks ago), but no result!!!
I,m on 3d view and webgl is ok on my computer, but scene view can not load more than 3000 features!! :
In the 4.x api you can use webgl rendering to allow for hundreds of thousands of features.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#webgl-rendering
test if if your browser supports this feature
Detect WebGL support | ArcGIS API for JavaScript 4.6
sample
FeatureLayer performance improvements [beta] | ArcGIS API for JavaScript 4.6
