using System;using System.Collections.Generic;using System.IO;using System.Linq;using System.Text;using System.Windows;using System.Windows.Controls;using System.Windows.Data;using ESRI.ArcGIS.Client;using ESRI.ArcGIS.Client.Tasks;namespace ExportTest{ public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); } void QueryButton_Click(object sender, RoutedEventArgs e) { QueryTask queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/5"); queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted; queryTask.Failed += QueryTask_Failed; ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query(); query.Text = StateNameTextBox.Text; query.OutFields.Add("*"); queryTask.ExecuteAsync(query); } void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args) { FeatureSet featureSet = args.FeatureSet; if (featureSet != null && featureSet.Features.Count > 0) { QueryDetailsDataGrid.ItemsSource = args.FeatureSet; } else MessageBox.Show("No features returned from query"); } private void QueryTask_Failed(object sender, TaskFailedEventArgs args) { MessageBox.Show("Query execute error: " + args.Error); } private void Excel_Click(object sender, RoutedEventArgs e) { DataGridExtensions.ExportDataGrid(QueryDetailsDataGrid, null); } } public static class DataGridExtensions { public static void Export(this DataGrid dg, List<string> excludedColumns) { ExportDataGrid(dg, excludedColumns); } public static void ExportDataGrid(DataGrid dGrid, List<string> excludedColumns) { SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 }; if (objSFD.ShowDialog() == true) { string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper(); StringBuilder strBuilder = new StringBuilder(); if (dGrid.ItemsSource == null) return; if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All) { var listFields = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select col.Header.ToString(); BuildStringOfRow(strBuilder, listFields, strFormat); } foreach (Graphic data in dGrid.ItemsSource) { var listFields = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select GetValue(col.GetCellContent(data)); BuildStringOfRow(strBuilder, listFields, strFormat); } StreamWriter sw = new StreamWriter(objSFD.OpenFile()); if (strFormat == "XML") { //Let us write the headers for the Excel XML sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>"); sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">"); sw.WriteLine("<Author>Arasu Elango</Author>"); sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>"); sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>"); sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>"); sw.WriteLine("<Version>12.00</Version>"); sw.WriteLine("</DocumentProperties>"); sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<Table>"); } sw.Write(strBuilder.ToString()); if (strFormat == "XML") { sw.WriteLine("</Table>"); sw.WriteLine("</Worksheet>"); sw.WriteLine("</Workbook>"); } sw.Close(); } } private static string GetValue(FrameworkElement frameworkElement) { return frameworkElement == null ? null : (frameworkElement is TextBlock ? (frameworkElement as TextBlock).Text : frameworkElement.ToString()); } private static void BuildStringOfRow(StringBuilder strBuilder, IEnumerable<string> lstFields, string strFormat) { switch (strFormat) { case "XML": strBuilder.AppendLine("<Row>"); strBuilder.AppendLine(String.Join("", lstFields.ToArray())); strBuilder.AppendLine("</Row>"); break; case "CSV": strBuilder.AppendLine(String.Join(",", lstFields.ToArray())); break; } } private static string FormatField(string data, string format) { switch (format) { case "XML": return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data); case "CSV": return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", "")); } return data; } }}
private static string GetValue(DataGridColumn col, Graphic graphic) { if (col is DataGridBoundColumn) { var path = (col as DataGridBoundColumn).Binding.Path.Path; var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1"); return graphic.Attributes[att] == null ? string.Empty : graphic.Attributes[att].ToString(); } return string.Empty; }
foreach (Graphic data in dGrid.ItemsSource) { lstFields.Clear(); foreach (DataGridColumn col in dGrid.Columns) { string tempString = null; if (col is DataGridTextColumn) { tempString = ((DataGridTextColumn)col).Binding.Path.Path.ToString(); } else if (col is DataGridTemplateColumn) { //This is the case when the column has a hyperlink in the cell template HyperlinkButton innerControl = ((DataGridTemplateColumn)col).CellTemplate.LoadContent() as HyperlinkButton; if (innerControl != null) tempString = innerControl.GetBindingExpression(HyperlinkButton.ContentProperty).ParentBinding.Path.Path.ToString(); else tempString = string.Empty; } string attributeName = tempString.Replace("Attributes[", "").Replace("]", ""); string strValue = string.Empty; if (excludedColumns != null) { foreach (string columnName in excludedColumns) { if (col.Header.ToString() == columnName) { continue; } else { if (data.Attributes[attributeName] != null) strValue = data.Attributes[attributeName].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } } } else { if (data.Attributes[attributeName] != null) strValue = data.Attributes[attributeName].ToString(); lstFields.Add(FormatField(strValue, strFormat)); } } BuildStringOfRow(strBuilder, lstFields, strFormat); }
private static string GetValue(FrameworkElement frameworkElement) { return frameworkElement == null ? null frameworkElement is TextBlock ? (frameworkElement as TextBlock).Text : frameworkElement.ToString()); }
private static string GetValue(DataGridColumn col, Graphic graphic) { if (col is DataGridBoundColumn) { var path = (col as DataGridBoundColumn).Binding.Path.Path; var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1"); return graphic.Attributes[att].ToString(); } return string.Empty; }
string strValue = string.Empty; strValue = data.Attributes[field].ToString();
string strValue = data.Attributes[field] != null ? data.Attributes[field].ToString() : string.Empty;
string strValue = string.Empty; strValue = data.Attributes[field.Header.ToString()].ToString();
string strValue = data.Attributes[field.Header.ToString()] != null ? data.Attributes[field.Header.ToString()].ToString() : string.Empty;
public static class DataGridExtensions { //added the extra parameter public static void Export(this FeatureDataGrid dg, IEnumerable<Graphic> graphics, List<string> excludedColumns) { ExportDataGrid(dg, graphics, excludedColumns); } //added the extra parameter public static void ExportDataGrid(FeatureDataGrid dGrid, IEnumerable<Graphic> graphics, List<string> excludedColumns) { SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 }; if (objSFD.ShowDialog() == true) { string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper(); StringBuilder strBuilder = new StringBuilder(); if (dGrid.ItemsSource == null) return; if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All) { var listFields = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select col.Header.ToString(); BuildStringOfRow(strBuilder, listFields, strFormat); } //this line changed a little foreach (Graphic graphic in graphics) { var listValues = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select GetValue(col, graphic); BuildStringOfRow(strBuilder, listValues, strFormat); } StreamWriter sw = new StreamWriter(objSFD.OpenFile()); if (strFormat == "XML") { //Let us write the headers for the Excel XML sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>"); sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">"); sw.WriteLine("<Author>Arasu Elango</Author>"); sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>"); sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>"); sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>"); sw.WriteLine("<Version>12.00</Version>"); sw.WriteLine("</DocumentProperties>"); sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<Table>"); } sw.Write(strBuilder.ToString()); if (strFormat == "XML") { sw.WriteLine("</Table>"); sw.WriteLine("</Worksheet>"); sw.WriteLine("</Workbook>"); } sw.Close(); } } private static string GetValue(DataGridColumn col, Graphic graphic) { if (col is DataGridBoundColumn) { var path = (col as DataGridBoundColumn).Binding.Path.Path; var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1"); return graphic.Attributes[att].ToString(); } return string.Empty; } private static void BuildStringOfRow(StringBuilder strBuilder, IEnumerable<string> lstFields, string strFormat) { switch (strFormat) { case "XML": strBuilder.AppendLine("<Row>"); strBuilder.AppendLine(String.Join("", lstFields.ToArray())); strBuilder.AppendLine("</Row>"); break; case "CSV": strBuilder.AppendLine(String.Join(",", lstFields.ToArray())); break; } } private static string FormatField(string data, string format) { switch (format) { case "XML": return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data); case "CSV": return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", "")); } return data; } }
//handle the Export All To Excel click private void exportAll_Click(object sender, RoutedEventArgs e) { FeatureLayer fe = (FeatureLayer)MyMap.Layers["California"]; //ete.ExportData(fe.Graphics.ToList(), MyDataGrid.Columns); MyDataGrid.Export(fe.Graphics, null); } private void exportSelected_Click(object sender, RoutedEventArgs e) { FeatureLayer fe = (FeatureLayer)MyMap.Layers["California"]; //ete.ExportData(fe.SelectedGraphics.ToList(), MyDataGrid.Columns); MyDataGrid.Export(fe.SelectedGraphics.ToList(), null); }
return graphic.Attributes[path] == null ? string.Empty : graphic.Attributes[path].ToString();
private static string GetValue(DataGridColumn col, Graphic graphic) { if (col is DataGridBoundColumn) { DataGridBoundColumn column = col as DataGridBoundColumn; if ((column.Binding != null) && (column.Binding.Path != null)) { string path = column.Binding.Path.Path; if (!string.IsNullOrEmpty(path)) { var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1"); return graphic.Attributes[att].ToString(); } } } return string.Empty; }
public static class DataGridExtensions { public static void Export(this FeatureDataGrid dg, IEnumerable<Graphic> graphics, List<string> excludedColumns) { ExportDataGrid(dg, graphics, excludedColumns); } public static void ExportDataGrid(FeatureDataGrid dGrid, IEnumerable<Graphic> graphics, List<string> excludedColumns) { SaveFileDialog objSFD = new SaveFileDialog() { DefaultExt = "csv", Filter = "CSV Files (*.csv)|*.csv|Excel XML (*.xml)|*.xml|All files (*.*)|*.*", FilterIndex = 1 }; if (objSFD.ShowDialog() == true) { string strFormat = objSFD.SafeFileName.Substring(objSFD.SafeFileName.IndexOf('.') + 1).ToUpper(); StringBuilder strBuilder = new StringBuilder(); if (dGrid.ItemsSource == null) return; if (dGrid.HeadersVisibility == DataGridHeadersVisibility.Column || dGrid.HeadersVisibility == DataGridHeadersVisibility.All) { var listFields = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select FormatField(col.Header.ToString(), strFormat); BuildStringOfRow(strBuilder, listFields, strFormat); } foreach (Graphic graphic in graphics) { var listValues = from col in dGrid.Columns where excludedColumns == null || !excludedColumns.Contains(col.Header.ToString()) select FormatField(GetValue(col, graphic), strFormat); BuildStringOfRow(strBuilder, listValues, strFormat); } StreamWriter sw = new StreamWriter(objSFD.OpenFile()); if (strFormat == "XML") { //Let us write the headers for the Excel XML sw.WriteLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>"); sw.WriteLine("<?mso-application progid=\"Excel.Sheet\"?>"); sw.WriteLine("<Workbook xmlns=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<DocumentProperties xmlns=\"urn:schemas-microsoft-com:office:office\">"); sw.WriteLine("<Author>Arasu Elango</Author>"); sw.WriteLine("<Created>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</Created>"); sw.WriteLine("<LastSaved>" + DateTime.Now.ToLocalTime().ToLongDateString() + "</LastSaved>"); sw.WriteLine("<Company>Atom8 IT Solutions (P) Ltd.,</Company>"); sw.WriteLine("<Version>12.00</Version>"); sw.WriteLine("</DocumentProperties>"); sw.WriteLine("<Worksheet ss:Name=\"Silverlight Export\" xmlns:ss=\"urn:schemas-microsoft-com:office:spreadsheet\">"); sw.WriteLine("<Table>"); } sw.Write(strBuilder.ToString()); if (strFormat == "XML") { sw.WriteLine("</Table>"); sw.WriteLine("</Worksheet>"); sw.WriteLine("</Workbook>"); } sw.Close(); } } private static string GetValue(DataGridColumn col, Graphic graphic) { if (col is DataGridBoundColumn) { DataGridBoundColumn column = col as DataGridBoundColumn; if ((column.Binding != null) && (column.Binding.Path != null)) { string path = column.Binding.Path.Path; if (!string.IsNullOrEmpty(path)) { var att = Regex.Replace(path, ".*\\[(.*)\\]", "$1"); return graphic.Attributes[att].ToString(); } } } return string.Empty; } private static void BuildStringOfRow(StringBuilder strBuilder, IEnumerable<string> lstFields, string strFormat) { switch (strFormat) { case "XML": strBuilder.AppendLine("<Row>"); strBuilder.AppendLine(String.Join("", lstFields.ToArray())); strBuilder.AppendLine("</Row>"); break; case "CSV": strBuilder.AppendLine(String.Join(",", lstFields.ToArray())); break; } } private static string FormatField(string data, string format) { switch (format) { case "XML": return String.Format("<Cell><Data ss:Type=\"String\">{0}</Data></Cell>", data); case "CSV": return String.Format("\"{0}\"", data.Replace("\"", "\"\"\"").Replace("\n", "").Replace("\r", "")); } return data; } }
resultFeature.Attributes.Add("OWNADDRESS_FULL", resultFeature.Attributes["OWNADDRESS"] + "\r" + (resultFeature.Attributes["OWNCITYST"] + " " + resultFeature.Attributes["OWNZIPCODE"]).Trim()); // + "\r" + resultFeature.Attributes["OWNCOUNTRY"]);
Sorry I zipped the wrong file :
First off, thank you for providing this code. It works pretty well for me if I am not exporting more than 10-15 records at a time. Anymore than that then it starts either dropping data or wont save. Screencap of an exported csv. Are there limits to how much data can be exported? I have found that if I export data from a datagrid that has fewer columns I am able to export more records before it either doesn't work or stops populating columns.
