Sub OnFormCancel Dim bResult bResult = Application.MessageBox ("Are you sure you want to cancel?", apYesNo, "Cancel?") If bResult = apNo Then ThisEvent.Result = False End If If bResult = apYes Then ThisEvent.Result = True End If End Sub
Sub ValidateUserPTwo Dim objPg Set objPg = ThisEvent.Object If objPg.Controls("cboDP").value = "" Then ThisEvent.Result = False ThisEvent.MessageText = "You must select a Discharge Point Layer to Continue" ThisEvent.MessageType = apOKOnly + apExclamation Exit Sub End If ThisEvent.Result = True End Sub
