Dear My Friends ,
Actually I will try to Add image in each features
ex ( I have wells , I need each well has photo , when I click for well , I will see picture ..)
how can do that in flex ??
thanks for helping
Regards,
Mohammed
Mohammed,
are are your images stored as attachments in your database or as files in your file system.
if they are attachments, you can use the showattachments attribute in the popup configuration:
ArcGIS Viewer for Flex
if you you have them as images on your file system then you will need to create a virtual directory on your web server so that you can access each image by a URL, more info can be found in numerous other threads on the forum such as:
https://community.esri.com/thread/55128?start=0&tstart=0
regards
Anthony
Thanks Anthony for your answer..
