If you use 'Add All Values' when you're setting up your symbology, even blank fields will be included. In fact I think if you click on the blank value in the symbology tab in layer properties it will highlight a single space...If you don't want features with a blank value in that field to be symbolized, just remove that value from the symbology properties (and make sure '<all other values>' is unticked.Hope that helpsDan
!field_name!.strip()
