Hi Charles,Is this occurring for any raster dataset you try to rectify, or is it just one in particular?Do you have Service Pack 1 installed?
Are you trying to save the raster dataset to a local or network drive? If the latter, try saving the raster dataset to a local drive you know you have write permissions to.
Using ArcMap 10.1 in XPsp3. I can't rectify a georeferenced image. The procedure returns the erorr: "Failed to save raster dataset". Occurs when trying to generate a .tif or any of the compressed formats.
Thanks @ Shiko!All my raster datasets start with a year as in 1990xxxx. You mentinoned "...name is invalid...." and that was it, renaming into b1990xxxx solved my problem.
Yes this is the best solution of using the letters in front of any number. I had the same issue and found this discussion. Recommend posting fix on 10.1 and previous versions boards. Thanks for your help...
Thanks so much for figuring out the name issue. I just spent over an hour trying to figure out why I couldn't rectify a raster dataset. Turns out it was because I was using the year at the beginning of the output name. A more informative error message would be really helpful there.
Almost 8 years later and this reply saved me! ArcGIS Pro does not auto-fill in the raster file type for the Change Detection Wizard so I needed to add the .tif suffix
