After running the script below the "point" layer that is created does not have any features and of course no angles calculated. Any ideas on why this might be would be appreciated.
Jim
<SPAN class="keyword token">import</SPAN> math
<SPAN class="number token">02</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> sr <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Z77"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>spatialReference
<SPAN class="number token">03</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CreateFeatureclass_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'in_memory'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'points'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"POINT"</SPAN><SPAN class="punctuation token">,</SPAN>spatial_reference<SPAN class="operator token">=</SPAN>sr<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">04</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>AddField_management<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'points'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'Angle'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"DOUBLE"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">05</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> insCur <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"points"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'SHAPE@'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'Angle'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">06</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Z77"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"SHAPE@"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">07</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">08</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> part <SPAN class="keyword token">in</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">09</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> pt_count <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="number token">10</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">for</SPAN> pnt <SPAN class="keyword token">in</SPAN> part<SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">11</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> pnt <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>PointGeometry<SPAN class="punctuation token">(</SPAN>pnt<SPAN class="punctuation token">,</SPAN>sr<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">12</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">if</SPAN> pt_count <SPAN class="operator token">></SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">13</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">if</SPAN> pt_count <SPAN class="operator token">></SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="number token">14</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> distAB <SPAN class="operator token">=</SPAN> oneBack<SPAN class="punctuation token">.</SPAN>distanceTo<SPAN class="punctuation token">(</SPAN>twoBack<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">15</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> distBC <SPAN class="operator token">=</SPAN> pnt<SPAN class="punctuation token">.</SPAN>distanceTo<SPAN class="punctuation token">(</SPAN>oneBack<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">16</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> distAC <SPAN class="operator token">=</SPAN> pnt<SPAN class="punctuation token">.</SPAN>distanceTo<SPAN class="punctuation token">(</SPAN>twoBack<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">17</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> angB <SPAN class="operator token">=</SPAN> math<SPAN class="punctuation token">.</SPAN>degrees<SPAN class="punctuation token">(</SPAN>math<SPAN class="punctuation token">.</SPAN>acos<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>distAB<SPAN class="operator token">*</SPAN>distAB<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>distBC<SPAN class="operator token">*</SPAN>distBC<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="punctuation token">(</SPAN>distAC<SPAN class="operator token">*</SPAN>distAC<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="operator token">*</SPAN>distAB<SPAN class="operator token">*</SPAN>distBC<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">18</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> insCur<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>oneBack<SPAN class="punctuation token">,</SPAN>angB<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">19</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> twoBack <SPAN class="operator token">=</SPAN> oneBack
<SPAN class="number token">20</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> oneBack <SPAN class="operator token">=</SPAN> pnt
<SPAN class="number token">21</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> pt_count <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="number token">22</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">del</SPAN> insCur
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
