//CREATE THE TABLE IN AN IN MEMORY WORKSPACE IObjectClassDescription ocDescription = new ObjectClassDescriptionClass(); Type factoryType = Type.GetTypeFromProgID( "esriDataSourcesGDB.InMemoryWorkspaceFactory"); IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance (factoryType); IWorkspaceName workspaceName = workspaceFactory.Create("", "in_memory", null, 0); IName name = (IName)workspaceName; IFeatureWorkspace fws = (IFeatureWorkspace)name.Open(); string tableName = "tempTable"; ITable table = fws.CreateTable(tableName, fields, ocDescription.ClassExtensionCLSID, null, "");
pRow.Value(pRow.Fields.FindField("PipeFID")) = "myvalue"
The workspace is not connected.
Private Sub createDataTable() 'This function creates a table in memory to store data Dim pFields As IFields Dim pFieldsEdit As IFieldsEdit Dim pField As IField Dim pFieldEdit As IFieldEdit Set pFields = New Fields Set pFieldsEdit = pFields pFieldsEdit.FieldCount = 4 Set pField = New Field Set pFieldEdit = pField With pFieldEdit .Length = 10 .Name = "OID" .Type = esriFieldTypeOID .IsNullable = False End With Set pFieldsEdit.Field(0) = pField Set pField = New Field Set pFieldEdit = pField With pFieldEdit .Length = 20 .Name = "PipeFID" .Type = esriFieldTypeString End With Set pFieldsEdit.Field(1) = pField Set pField = New Field Set pFieldEdit = pField With pFieldEdit .Length = 10 .Name = "ParcelsWI" .Type = esriFieldTypeInteger End With Set pFieldsEdit.Field(2) = pField Set pField = New Field Set pFieldEdit = pField With pFieldEdit .Length = 10 .Name = "ParcelsWIB" .Type = esriFieldTypeInteger End With Set pFieldsEdit.Field(3) = pField 'Create the table using the created fields Dim pRecordSet As IRecordSet Set pRecordSet = New RecordSet Dim pRSInit As IRecordSetInit Set pRSInit = pRecordSet pRSInit.CreateTable pFields Set FinalTable = pRecordSet.table End Sub
Dim pRow As IRow Set pRow = FinalTable.CreateRow pRow.Value(pRow.Fields.FindField("PipeFID")) = "myvalue" pRow.Value(pRow.Fields.FindField("ParcelsWI")) = 5 pRow.Value(pRow.Fields.FindField("ParcelsWIB")) = 2 pRow.Store
