we would like to find out how to know if the ArcGIS Server's cluster being used?
here's the spec of our arcgis server:
Machine #1: ArcGIS Server 10.1
Machine #2: ArcGIS Server 10.1 Cluster
Windows 2008 R2
thank you!
Wilson
You can use ArcGIS server manager using 6080 port or using web adapter port,
http://localhost:6080/arcgis/manager http://localhost:7120/arcgis/manager Which type of statics you want to check,
Map services related things you can check in logs>statics
Example: Export service statistics to a file—Documentation (10.4) | ArcGIS for Server
Please check this for more info,
Multiple-machine deployment with ArcGIS Web Adaptor—Installation Guides (10.4.1) | ArcGIS for Server
If you want to get an idea of how many requests are going to one machine vs another within a multi-machine site, you can set the logs to Info and then query them, which will contain a machine column. You can take a look at the total counts for requests to the each machines and compare them. Below is a sample python script to query the logs which you can modify to count the requests to each machine.
Example: Query the ArcGIS Server logs—Documentation (10.4) | ArcGIS for Server
