there is no real way to manually call those methods on map for every single combination on when the map is going to be displaced.
It has to be an event that tells you when the reposition happen.
It only works when you resize the the browser window, but when you use the plank I shared, and add things to the dom, which causes the map to reposition, that event is not fired.
