We purposely (for a use case) do not re-center map on user's location and keep map rotated in the last direction while transitioning from AGSGPSAutoPanModeCompassNavigation to AGSGPSAutoPanModeOff.I'm not sure whether you have noticed this but if you're in navigation mode (AGSGPSAutoPanModeCompassNavigation) and driving, now you want to see/check the map around current location and you try to touch/pan/zoom map then it automatically changes to the AGSGPSAutoPanModeOff. If at this time SDK re-center the map or auto-correct the angle then it'll will look really bad.We're leaving this situation to handle to the develop so they can do as per desired and what is right for their apps to behave.Hope this helps!Regards,Nimesh
It's just one line of code for you and we're leaving that choice on the developers if they want to do it.Regards,Nimesh
