Hi all.. i am trying to implement an function by which we can export query task result data grid as a CSV file.
Is there any widget available for this function. I am using 4.8 arcgis javascript .. any ideas or samples with latest versions..
Thanks..
Sure. One thing I forgot that I forgot is that featureHeaders is not actually an array but a comma delimited string (you can just call the toString() method on the array). Also, featureArray is an array of strings not a 2d array (i'll edit my original response). Anyway, I'll take the example QueryTask from the API reference here and modify it to pass results to my exportData function:
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/tasks/QueryTask"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/tasks/support/Query"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>QueryTask<SPAN class="punctuation token">,</SPAN> Query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> citiesLayerUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token">" ... "</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Represents the REST endpoint for a layer of cities.</SPAN> <SPAN class="keyword token">var</SPAN> fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"cityName"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"countryName"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"POP"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Made up some fields</SPAN> <SPAN class="keyword token">var</SPAN> queryTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTask</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> citiesLayerUrl <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> query <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Query</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> query<SPAN class="punctuation token">.</SPAN>outFields <SPAN class="operator token">=</SPAN> fields<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Use the array of fields from above</SPAN> query<SPAN class="punctuation token">.</SPAN>where <SPAN class="operator token">=</SPAN> <SPAN class="string token">"POP > 1000000"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Return all cities with a population greater than 1 million</SPAN> <SPAN class="comment token">// When resolved, returns features and graphics that satisfy the query.</SPAN> queryTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>query<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>results<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> exportFields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> exportHeaders <SPAN class="operator token">=</SPAN> fields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> features <SPAN class="operator token">=</SPAN> results<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>f <SPAN class="keyword token">in</SPAN> features<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> row <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="keyword token">in</SPAN> targetLayer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> row <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> features<SPAN class="punctuation token">[</SPAN>f<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">[</SPAN>targetLayer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">!==</SPAN> <SPAN class="punctuation token">(</SPAN>targetLayer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> row <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> <SPAN class="string token">","</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> exportFields<SPAN class="punctuation token">.</SPAN><SPAN class="token function">push</SPAN><SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token function">exportData</SPAN><SPAN class="punctuation token">(</SPAN>exportFields<SPAN class="punctuation token">,</SPAN> exportHeaders<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi James..Thanks for the reply. Here we are exporting results to CSV for only one URL and its features.. What can i do if i am having more than 2 featurem URLs with different fields.. How to use your same function..?
Hello james.. it was really helpful but can you please give me an example by using this function..
I'm not aware of an out-of-the-box solution but I wrote a function to export results from a query for a web map that I created.
It takes an array of strings ( i.e. ["field1, field2, field3", "field1, field2, field3"]) and an array of field names. It then puts that all into a CSV formatted string and encodes that as a URI and attaches that to a href element.
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">exportData</SPAN><SPAN class="punctuation token">(</SPAN>featureArray<SPAN class="punctuation token">,</SPAN> featureHeaders<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// creates downloadable csv file of selected features</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"status"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Generating Download Link..."</SPAN> <SPAN class="keyword token">var</SPAN> csvContent <SPAN class="operator token">=</SPAN> <SPAN class="string token">"data:text/csv;charset=utf-8,"</SPAN><SPAN class="punctuation token">;</SPAN> csvContent <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> featureHeaders <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\r\n"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>x <SPAN class="keyword token">in</SPAN> featureArray<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> csvContent <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> featureArray<SPAN class="punctuation token">[</SPAN>x<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\r\n"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> encodedUri <SPAN class="operator token">=</SPAN> <SPAN class="token function">encodeURI</SPAN><SPAN class="punctuation token">(</SPAN>csvContent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// the div where the link will be placed</SPAN> <SPAN class="keyword token">var</SPAN> searchDiv <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"searchDiv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Get link element or create it if it does not exist yet</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"downloadLink"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>link <SPAN class="operator token">==</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">throw</SPAN> <SPAN class="string token">"nullException"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">e</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> link <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"a"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">finally</SPAN><SPAN class="punctuation token">{</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"href"</SPAN><SPAN class="punctuation token">,</SPAN> encodedUri<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"download"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"data.csv"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setAttribute</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"id"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"downloadLink"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN>innerHTML<SPAN class="operator token">=</SPAN> <SPAN class="string token">"Download Feature List"</SPAN><SPAN class="punctuation token">;</SPAN> link<SPAN class="punctuation token">.</SPAN>hidden <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">;</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"status"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>innerHTML <SPAN class="operator token">=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">;</SPAN> searchDiv<SPAN class="punctuation token">.</SPAN><SPAN class="token function">appendChild</SPAN><SPAN class="punctuation token">(</SPAN>link<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
