Hi there, I am exploring the use of GIS to map the location of each CCTV camera that is mounted on building. I was able to geocoded each CCTV camera location on 2D map however would like to seek your opinion on the following:Q1: I noticed there is limitation of using ArcGIS desktop to auto create the viewing area (this would be a polygon form) from each planted camera. May I know is there a third party software/any script I can use to generate the viewing coverage from each camera, the viewing coverage looks like a cone shape. Look forward to hearing any further sharing, thanks. See the attached images. [ATTACH=CONFIG]23493[/ATTACH][ATTACH=CONFIG]23494[/ATTACH][ATTACH=CONFIG]23493[/ATTACH]
This is not much unlike mapping Cell Phone Tower quadrants and/or other Radio Antenna broadcast coverage or other viewshed analyses. There is also a plume modeling extension from NOAA called Aloha that you might want to check out as well.
from math import radians, sin, cos import pprint import arcpy arcpy.env.overwriteOutput = True arcpy.env.workspace = r'C:\gis\cellTowers\missedTowers.gdb' def getEndXY(origin_x, origin_y, distance, angle): (disp_x, disp_y) = (distance * sin(radians(angle)),\ distance * cos(radians(angle))) (end_x, end_y) = (origin_x + disp_x, origin_y + disp_y) return end_x, end_y def makeCellSector(startX, startY, azimuth): distance = 15000 offsetAzimuthA = azimuth - (60) offsetAzimuthB = azimuth + (60) arcpy.CreateFeatureclass_management( 'in_memory', 'temp', 'Polygon') cur = arcpy.InsertCursor('in_memory\\temp') polyArray = arcpy.Array() start = arcpy.Point() (start.ID, start.X, start.Y) = (1, startX, startY) polyArray.add(start) a = arcpy.Point() ax , ay = getEndXY(startX, startY, distance, offsetAzimuthA) (a.ID, a.X, a.Y) = (2, ax, ay) polyArray.add(a) b = arcpy.Point() bx, by= getEndXY(startX, startY, distance, offsetAzimuthB) (b.ID, b.X, b.Y) = (3, bx, by) polyArray.add(b) close = arcpy.Point() (close.ID, close.X, close.Y) = (4, startX, startY) polyArray.add(close) feat = cur.newRow() feat.shape = polyArray cur.insertRow(feat) polyArray.removeAll() del cur towers = {} fields = ['CellNumber', 'Sector', 'City', 'Azimuthdeg', 'POINT_X', 'POINT_Y'] with arcpy.da.SearchCursor('missedTowers', fields) as c: for r in c: towers[r[0], r[1], r[2]] = r[3],r[4],r[5] for k, v in towers.iteritems(): print k print v arcpy.MakeFeatureLayer_management('missedTowers', 'towerLyr', '"CellNumber" = ' + str(int(k[0])) + ' AND "City" = ' + "'" + k[2] +"'") arcpy.Buffer_analysis('towerLyr', 'in_memory\\buffer', '1 mile') arcpy.DeleteIdentical_management('in_memory\\buffer', 'Shape') makeCellSector(v[1], v[2], v[0]) print 'made sector' name = k[2] + '_' +str(int(k[0])) + '_' + k[1] arcpy.Intersect_analysis(['in_memory\\buffer', 'in_memory\\temp'], name, 'ONLY_FID', '#', 'INPUT') print 'intersect complete' arcpy.Delete_management('towerLyr') arcpy.Delete_management('in_memory\\temp') arcpy.Delete_management('in_memory\\buffer')
