Private Sub ICEWR_Click() On Error GoTo ERRORR Dim pGxDialog As IGxDialog Set pGxDialog = New GxDialog pGxDialog.ButtonCaption = "Add" pGxDialog.StartingLocation = "D:\Data" pGxDialog.Title = "Add the shapefile you wish to integrate and collect events" pGxDialog.AllowMultiSelect = True Dim pLFilter As IGxFile Set pLFilter = New GxFile Dim pGxFilter As IGxObjectFilter Set pGxFilter = New GxFilterShapefiles Set pGxDialog.ObjectFilter = pGxFilter Dim pLayerFiles As IEnumGxObject pGxDialog.DoModalOpen 0, pLayerFiles 'Dim pLayerFile As IGxObject Dim pLayerFile As IGxDataset Set pLayerFile = pLayerFiles.Next 'Dim pGxLayer As IGxLayer Dim pGxLayer As IFeatureLayer Dim pGxFeatureClass As IFeatureClass Set pGxFeatureClass = pLayerFile.Dataset Set pGxLayer = New FeatureLayer Set pGxLayer.FeatureClass = pGxFeatureClass pGxLayer.Name = pGxFeatureClass.AliasName theshapefile = pGxLayer.Name Dim pMxDoc As IMxDocument Set pMxDoc = ThisDocument pMxDoc.AddLayer pGxLayer pMxDoc.ActiveView.Refresh pMxDoc.UpdateContents Dim pMap As IMap Set pMap = pMxDoc.FocusMap For i = 0 To pMap.LayerCount - 1 If pMap.Layer(i).Name = theshapefile Then getindex = i End If Next i Dim pl2 As IDataLayer2 Set pl2 = pMxDoc.FocusMap.Layer(getindex) Dim pdsNAME As IDatasetName Set pdsNAME = pl2.DataSourceName theworkarea = pdsNAME.WorkspaceName.PathName & "\" SF_Copy = theworkarea & theshapefile & "_copy.shp" SF_Copier = SF_Copy & " #" SF_COUNT = theworkarea & theshapefile & "_collectevents.shp" SF_INTEGRATED = theworkarea & theshapefile & "_integrated.shp" SF_Rendered = theworkarea & theshapefile & "_rendered" toly = InputBox("Enter a tolerance value for integration please", "Tolerance") ' Create the Geoprocessor object Set gp = CreateObject("esriGeoprocessing.GPDispatch.1") ' Load required toolboxes... gp.AddToolbox "D:/ArcGIS/ArcToolbox/Toolboxes/Spatial Statistics Tools.tbx" gp.AddToolbox "D:/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx" ' Process: Copy Features... gp.CopyFeatures_management theshapefile, SF_Copy, "", "0", "0", "0" gp.Integrate_management SF_Copier, toly gp.CollectEvents_stats SF_Copy, SF_COUNT gp.CountRenderer_stats SF_COUNT, "ICOUNT", SF_Rendered, "5", "bright_pink", "" Exit Sub ERRORR: MsgBox "You may have already run this and forgotten to delete files created last time", vbCritical, "Error" 'will add a file check and delete to overcome this problem when i get time End Sub
How about this? shapefile = "c://temp//shapefile.shp"That's a joke, kind of. What exactly are you trying to do ? What do you mean by open? Why can't the user add a shapefile to ArcMap and then open its attribute table or what ever it wants to do there? What's the desired process or end result? What does the user need to do with the shapefile once its been opened?
Try posting your entire code, use code blocks, like this and hopefully we can get to the bottom of your problem.
like this
# Import system modules import sys, string, os, arcgisscripting # get the shapefile from Tkinter import * import tkFileDialog # Create the Geoprocessor object gp = arcgisscripting.create() master = Tk() master.withdraw() #hiding tkinter window file_path = tkFileDialog.askopenfilename(initialdir="D:\\", title="Open file", filetypes=[("Shapefile",".shp"),("All files",".*")]) if file_path.find('.shp') == -1: print "Not a shapefile, quiting" master.quit() if file_path != "": print "you chose file with path:", file_path SF = file_path else: print "you didn't open anything!" sys.exit() def rchop(thestring, ending): if thestring.endswith(ending): return thestring[:-len(ending)] return thestring #get the tolerance toly = 0 from tkMessageBox import askokcancel class Quitter(Frame): def __init__(self, parent=None): Frame.__init__(self, parent) self.pack() widget = Button(self, text='Done', command=self.quit) widget.pack(expand=YES, fill=BOTH, side=BOTTOM) def quit(self): gp.addmessage('You chose ' + ent.get() + ' for the tolerance...well played!') toly = ent.get() gp.addmessage(toly) gp.addmessage(toly) #local variables SF_Copy = rchop(file_path, '.shp') + '_copy.shp' SF_Copier = SF_Copy + " #" SF_COUNT = rchop(file_path, '.shp') + '_collectevents.shp' SF_Integrated = rchop(file_path, '.shp') + '_integrated.shp' SF_Rendered = rchop(file_path, '.shp') + '_rendered' # Load required toolboxes... gp.AddToolbox("D:/ArcGIS/ArcToolbox/Toolboxes/Spatial Statistics Tools.tbx") gp.AddToolbox("D:/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx") ## Process: Copy Features... gp.CopyFeatures_management(SF, SF_Copy, "", "0", "0", "0") gp.addmessage('Backup copy has been made') ## Process: Integrate... gp.Integrate_management(SF_Copier, toly) gp.addmessage('Integration completed') ## Process: Collect Events... gp.CollectEvents_stats(SF_Copy, SF_COUNT) gp.addmessage('Events have been collected') SF_COUNT = SF_COUNT.replace("/","\\") SF_Rendered = SF_Rendered.replace("/","\\") gp.addmessage('Creating ' + SF_COUNT) gp.addmessage('Creating ' + SF_Rendered) # Process: Count Rendering... gp.CountRenderer_stats(SF_COUNT, "ICOUNT", SF_Rendered, "5", "bright_pink" ,"") Frame.quit(self) gp.addmessage('done and dusted') #this bit was me having a crack at adding it to the TOC gp.MakeFeatureLayer_management(SF_Rendered, "Untitled") gp.RefreshActiveView() root = Tk() root.title("Enter the tolerance value for integrate tool") L1 = Label(root, text="Enter the tolerance value for integrate tool (m): ") L1.pack( side = LEFT) ent = Entry(root) ent.insert(0, '20') #ent.pack(side=TOP, fill=X) ent.pack(side=LEFT) ent.focus() #ent.bind('<Return>', (lambda event: quitter())) ent.bind(toly, (lambda event: quitter())) #btn = Button(root, text='Fetch', command=fetch) #btn.pack(side=LEFT) Quitter(root).pack(side=RIGHT) root.mainloop()
Are you running this as a script tool or as a separate instance?
Doesn't matter, it is a basic tool available in any recent python package. You just use your arcgisscripting instance instead of arcpy.http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=1867&pid=1865&topicname=Make_Feature_Layer_(Data_Management
arcpy.MakeFeatureLayer_management(yourShapefile, "TOC name") arcpy.RefreshActiveView()
Greetings,I am an amatuer when it comes to python so could someone please help with my simple questions:1) Is the arcpy module available in ArcGIS 9.3 (I think it is 10 / python 2.6)2) What is the python code to open a shapefile in ArcGIS 9.3 (not using arcpy module)?Thanks,Josh
