...for each polyline in my mapservice - i need x,y,z values. Can I do this?
I can't get geometry property from feature layer because it returns a String value
...since new MapPoint takes only x,y...
Assuming you are using version 3.0 or later
Yes, the map points of the arrays in the polylines should have a "z" property if your feature layer supports "z".
Not sure how you are doing this, but you should be able to get the x/y/z from each feature in your feature layer.
<fx:Declarations> <esri:FeatureLayer id="road_layer" url="http://xyz/ArcGIS/rest/services/xyz/FeatureServer/0" returnZ="true"/> </fx:Declarations> //And now in Script tag I tried to read this layer details so: var layerDet:LayerDetails = road_layer.layerDetails;
This isn't true (if you are using the 3.0 API), see the http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/geometry/MapPoint.html
var mPoint:MapPoint = new MapPoint( 100, 100, new SpatialReference(102100)); mPoint.z = {some_value}; mPoint.m = {some_value};
