I want to calculate river miles. There are point locations that I need to calculate their mile posting as well. I have a Line Feature of a river centerline along with point locations. The easy way to achieve this is the measure tool but after reading about linear referencing tools to near tool I tried it all but with no progress. I tried calibrate route tool and used that and Locate features along route tool but that table was empty. If you are going ot respond answer in layman's terms and don't be too technical. Just lay it out in steps.
You can calculate the length of the line in miles by opening the attribute table and adding a field "MILES" and then right click the miles field and click "calculate geometry" select "miles" as units and then it will populate the length for you. Then you can create a route using "length" as your measure source. (I don't think you will need a from and to field but if you get an error, just add a field "FROMMILES" or something like that and use the field calculator to populate it with 0's (your TO field is your "MILES" field)) There might be a tool that can do this for you but manually you can use the "identify route location" on the Linear Referencing toolbar to get the milepost value at each point and use calculate field (or a model builder tool with input parameters) to add it to your milepost field in your point layer. NOTE: If your river layer contains drastic changed in elevation you will need to find the geodesic distance, I do this by overlaying my lines on a DEM but there might be an easier way.
I know this thread is from a decade ago. Hopefully you are still around (or someone could chime in too).
For branched routes (e.g., for calculating river miles for streams that have multiple tributaries), this sounds like one needs to manually enter the From information for each branch. Is there a way to automate this in arcgis?
Also i am unsure how to obtain the distance information from the route from which the branch begins. i cannot click on the line to get the distance. do i need to make a point dataset where this accumulated distance information is stored? i created an event table that seems to have this accumulated distance information but i am unsure how to associate this event table with the point data.
