Sure... just thinking, but if I get time, maybe I can show you how to correctly implement it as a script tool, with a few small modifications of course.If you want, send an xlsx copy containing a couple of abbreviated worksheets you haven't done yet - zip and attach here if not too big.I say 'abbreviated' because of the size limit you can successfully attach...it's quick and easy to maybe attach 1000 records or so each onto 2 sheets. (2 sheets are better than 1 because then you'll see the result of looping on the sheets - I could partition it myself, but would rather you do it so that it's as 'original' as possible...I'll note anything I may have to 'fix' to make the run successful.)You also have 10.0, so whatever I zip and attach you should be able to unzip and execute, simple as that. I'll make the toolbox 'relative-pathed' to be able to find both the py script and the larger set of sample data you send, no matter where you place it. You'll see how it runs and apply it to the rest of your xlsx data.How does that sound? I'm just curious about it because it could be extremely useful for training purposes - newer users are much more comfortable (and sometimes less suspicious of ArcGIS) when they can use their data in this more immediate way, data that they've worked on in Excel... so it is almost like ArcGIS is 'conforming' to use data in another environment in an interoperable way rather than requiring the complete conversion up front. Still technically a conversion for the processing to complete, but I think it seems less intrusive to the user, at least.Enjoy,Wayne
Hello Jane, I am posting a Python snippet... very basic stuff, no error trapping, but it's so easy to modify to be made into a script tool, as you see fit. I think it's just good at first to post 'sample code' at least to show the idea or technique, then improve it if necessary.I'm not sure about the projection parameters -- very interesting topic though, and very important to get that right, please change those params as necessary to improve your results.This simply reads Excel for data that is defined (named ranges only), creates an xy multipoint event using an array and multipoint class. The 'trick' that may not be immediately apparent is where 5 lines need to be commented out if you don't want to 'see' the centroids as computed before projecting...it was easy to leave that in as related to Dan Patterson's comment about the error associated with finding the actual center. This is much more complex in terms of coordinate systems and transformation methods than it may initially seem. ...why the comparison was warranted. You probably cannot determine anything conclusive with this data, but there are differences in the 2 datasets (look at the attached zip, the contained gdb - the script is also listed below for viewing purposes):multipointPCS_1 (the projected GCS result, centroid computed before projecting)multipointPCS_2 (the PCS result, centroid computed after event layer was projected)Enjoy,Wayne import arcpy, os, sys arcpy.env.overwriteOutput = True scriptLoc = sys.argv[0] rootpath = scriptLoc.rsplit(os.sep)[0] arcpy.env.workspace = os.path.join(rootpath, 'avePairCoords.xlsx') rootpath = os.path.join(rootpath, 'stage.gdb') multipointGCS = os.path.join(rootpath, 'multipointGCS') multipointPCS_1 = os.path.join(rootpath, 'multipointPCS_1') multipointPCS_2 = os.path.join(rootpath, 'multipointPCS_2') installDir = arcpy.GetInstallInfo()['InstallDir'] SR_GCS = os.path.join(installDir, r'Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj') SR_PCS = os.path.join(installDir, r'Coordinate Systems\Projected Coordinate Systems\National Grids\Canada\NAD 1983 BC Environment Albers.prj') transform = 'WGS_1984_(ITRF00)_To_NAD_1983' arcpy.CreateFeatureclass_management(rootpath, 'multipointGCS', 'MULTIPOINT', os.path.join(rootpath, 'multipointGCS_template'), '', '', SR_GCS) arcpy.CreateFeatureclass_management(rootpath, 'multipointPCS_2', 'MULTIPOINT', os.path.join(rootpath, 'multipointPCS_template'), '', '', SR_PCS) pointArray = arcpy.Array() pnt = arcpy.Point() worksheets = arcpy.ListTables() sheets = [] for sheet in worksheets: if '$' not in sheet: sheets.append(sheet) rowsGCS = arcpy.InsertCursor(multipointGCS, SR_GCS) for sheet in sheets: print 'processing: ' + sheet fields = arcpy.ListFields(sheet) rows = arcpy.SearchCursor(sheet) for row in rows: ID = int(row.getValue(fields[0].name)) for i in range(2, len(fields), 3): lat, lon = row.getValue(fields.name), row.getValue(fields[i + 1].name) pnt.X, pnt.Y = lon, lat pointArray.add(pnt) feat = rowsGCS.newRow() multiPoint = arcpy.Multipoint(pointArray) feat.shape = multiPoint rowsGCS.insertRow(feat) pointArray.removeAll() # Comment out the following 4 lines below to prevent adding the centroid to the GCS output. # These lines were added to observe and experiment with processing the centroid before projecting the event layer. trueCentroid = multiPoint.trueCentroid feat = rowsGCS.newRow() feat.shape = trueCentroid rowsGCS.insertRow(feat) del row, rows, rowsGCS arcpy.Project_management(multipointGCS, multipointPCS_1, SR_PCS, transform) rowsPCS1 = arcpy.SearchCursor(multipointPCS_1) rowsPCS2 = arcpy.InsertCursor(multipointPCS_2) row = rowsPCS1.next() while row: feat1 = row.shape for pnt in feat1: pointArray.add(pnt) multiPoint = arcpy.Multipoint(pointArray) trueCentroid = multiPoint.trueCentroid feat2 = rowsPCS2.newRow() feat2.shape = multiPoint rowsPCS2.insertRow(feat2) feat2 = rowsPCS2.newRow() feat2.shape = trueCentroid rowsPCS2.insertRow(feat2) pointArray.removeAll() row = rowsPCS1.next() # This single following line below will also need commenting out as well if not processing the centroid GCS intermediate output. # If the multipoint row does not exist, then there is no need to skip an extra row on the search cursor. row = rowsPCS1.next() del row, rowsPCS1, rowsPCS2 print 'done.'
The centroid will be along a great circle and not simply the average of the latitudes and longitudes. It may be more appropriate to use projected data and the sample code provided to accomplish this task
input = "test_points" fieldName_01 = "cenLat" fieldName_02 = "cenLong" expression_01 = "(!StartLat!+!EndLat!)/2" expression_02 = "(!StartLong!+!EndLong!)/2" #Add fields arcpy.AddField_management(input,fieldName_01,"DOUBLE") arcpy.AddField_management(input,fieldName_02,"DOUBLE") #Calculate coordinate between the points arcpy.CalculateField_management(input,"centLat",expression,"PYTHON") arcpy.CalculateField_management(input,"cenLong",expression,"PYTHON")
