And my attributes will all have to have the same naming conventions, correct?
The bike/ped shapefiles I have are offset by varying distance to this centerline shapefile.Start/stops for each bike/ped facility do not necessarily connect from node to node.
i'm honestly not sure how you might accomplish this using python but a couple of thoughts come to mind:Are you able to do this in the context of a topology, if so, then editing the topology with appropriate rules can help manually editing these data be less painfulIf these already follow existing routes, can you simply utilize those data rather than creating new polylines? I expect you would have to have a way to identify start/stop points to define the routes. This process might be scriptable depending on how you go about it.Without more details about the nature of the data you're collecting its hard to comment more.
