Earlier version of SDK can set the text content fromw values from the graphic's attributes like below:
AGSTextSymbol *textSymbol = [AGSTextSymbol textSymbolWithTextTemplate:@${pointID} color:[UIColor redColor]];
How to do this in recent version?
Hello Lynn,
I think the method still using in 10.2.3. Please check this online documentation:10.2.3: AGSTextSymbol Class Reference
Hope this help.
Hi, Yue!
I red a document before. It saids the porperty 'text' will replace the porerty 'text template' after v10.2.2.
I tried 'text' porperty with the token like ${pointID}. But it doesn't work.
Did you test this function before? ??
Does it works?
If so , please show me some codes.
Thanks.
Hi Lynn,
I am not really sure what is ${pointID}? Is it point to your database field or something else?
Here are two snippet code to use this AGSTextSymbol textSymbolWith Text method:
NSString *stopString = @""; if (stopNumber != NSNotFound) { stopString = [NSString stringWithFormat:@%d, stopNumber]; } AGSTextSymbol *ts = [AGSTextSymbol textSymbolWithText:stopString color:[UIColor blackColor]];
Or
NSMutableString *word = [NSMutableString stringWithFormat:@Hello world]; AGSTextSymbol *txtSymbol = [AgSTextSymbol textSymbolWithText:word color:[UIColor redColor]];
Hi, Yue
Yes, the pointID is a field name of a graphic. In the old version of iOS SDK, I can use the property ‘textTemplate’ to set the text symbol text content of a graphic using its attribute field name but not a very string (just like your codes above). That will be very convenient. This function is very similar with the AGSCalloutTemplate 's titleTemplate.
I just like to know wether the AGSTextSymbol still supports this kind of template function.
