Just upgraded our portal to 10.7 and now cannot connect from Runtime application
Receive the following error:
The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
The remote certificate is invalid according to the validation procedure.
This same code worked at 10.6.1 (and has worked on previous versions). If I change to using agol it will work
<SPAN class="keyword token">public</SPAN> <SPAN class="keyword token">async</SPAN> Task<SPAN class="operator token"><</SPAN>TokenCredential<SPAN class="operator token">></SPAN> <SPAN class="token function">GetPortalCredential</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">string</SPAN> user<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">string</SPAN> password<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">try</SPAN>
<SPAN class="keyword token">var</SPAN> portalUri <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN>$<SPAN class="string token">"{ConfigurationSettings.PortalUrl}/sharing/rest"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> credential <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">await</SPAN> AuthenticationManager<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GenerateCredentialAsync</SPAN><SPAN class="punctuation token">(</SPAN>portalUri<SPAN class="punctuation token">,</SPAN> user<SPAN class="punctuation token">,</SPAN> password<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> credential<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">Exception</SPAN> e<SPAN class="punctuation token">)</SPAN>
_log<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Log</SPAN><SPAN class="punctuation token">(</SPAN>e<SPAN class="punctuation token">.</SPAN>Message<SPAN class="punctuation token">,</SPAN> Category<SPAN class="punctuation token">.</SPAN>Exception<SPAN class="punctuation token">,</SPAN> Priority<SPAN class="punctuation token">.</SPAN>None<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
