I'm playing around with Accessor and trying to return a Singleton but requiring the module anytime after first require on booting the app just returns an Object.
<SPAN class="comment token">// returns Singleton</SPAN>
<SPAN class="token function">define</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">'dojo/_base/declare'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/Stateful'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'dojo/Evented'</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>
declare<SPAN class="punctuation token">,</SPAN>
Stateful<SPAN class="punctuation token">,</SPAN>
Evented
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> _instance <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> Model <SPAN class="operator token">=</SPAN> <SPAN class="token function">declare</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>Stateful<SPAN class="punctuation token">,</SPAN> Evented<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// stuff</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>_instance<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
_instance <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Model</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> _instance<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// returns Object</SPAN>
<SPAN class="string token">'esri/core/Accessor'</SPAN><SPAN class="punctuation token">,</SPAN>
Accessor<SPAN class="punctuation token">,</SPAN>
Evented
<SPAN class="keyword token">var</SPAN> Model <SPAN class="operator token">=</SPAN> Accessor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createSubclass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>Evented<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
