“Extract Data Task” tool fails,
I couldn’t figure out why I got the error below as I apply the “Extract Data Task” tool.
What might be the issue here?
Software: ArcGIS 10.2.2 on windows 8.1
Thank you
Best
Jamal
The “select data” tool sounds to work as the input is web service.
For FGDB you need to add one more step to create each time new FGBD and save layer based on FGDB..Please try to add data management tool create new FGDB in you model..
https://community.esri.com/docs/DOC-8559
Correct. It works fine if the feature format is set to be shape file.
How the problem can be fixed if the feature format is set to be File Geodatabase?
Hi its your FGDB error,
extracted features are not written or copies to this,
Please use out put feature as shape file.
update once you received same error.
