I'm running a service area analysis and when I put my polygon generation settings to detailed most of the resulting polygons seem fine, but I end up with strange gaps in a few places that should be within the service areas. When I change the settings to generalized, the resulting polygons are including large areas of land that should be gaps within the second ring of my service area. I've included examples in the screen shots below (the blue lines and green dots are my SND, and the orange dots are my entrances/facilities.) If anyone has any insights into what might cause either of these issues, it would be much appreciated!
Other polygon generation settings I am using are:
Trim polygons: 200 meters
Merge by break value
Rings
Hello Cayce. I can't tell for sure without examining your data, but it looks to me like an issue with your network dataset. The areas with the strange gaps look like unreachable bits of the network. There are a couple of possible reasons for this:
You can use the Network Identify tool, accessed from the Network Analyst toolbar, to click on your network dataset edges and see some information about them and which other edges they are connected to.
Hope this helps you diagnose the problem!
Thank you very much Melinda!! I think I just figured it out. You were right, it was an issue with the network dataset. I discovered some duplicate line segments that were causing the problem. Thanks again!
