I have establish a enterprise database connection in arcmap. then i try to create a new dataset and I am receiving this error.
previously that database was working fine. I am not getting what happened this time.
Any suggestions please. ?
Can you access any current data in the geodatabase?
Those errors are pointing in the direction of a network/connection issues between ArcMap and your database server.
Thanks for reply George.
Yes I can access current geodatabase.
I can easily add data on arcmap from previously added data in database connection.
I have also tried to create dataset on server where database server and ArcGIS Enterprise server installed to confirm that is their connection error or something else.
Now, I have got attached error
Thanks in advance.
Did you review the error message and information related to the Esri article?
Problem: ArcGIS clients encounter errors related to table schema changes, app domain unloading, or fetch buffers when wo…
Yes i have reviewed the error message.
the windows server (2012 R2 standard) where SQL sever installed is of 32 GB RAM size. Its C drive has 150 GB space free.
and SQL server memory limit is set to max.
I am not getting what i should do next?
What are the resources of the SQL Server machine doing when this error occurs?
How often does it occur?
What are you doing to correct at this time?
