This is the structure of our SDE tree:�?� First SDE.Default�?� Second a child version from default called Pre-Production�?� Third an user version child of Pre-Production
My goal is to run a script that will perform the following operations: - move all the records that are completed in a feature class to an historical one, - and then remove features from the regular feature class that were archived.
I was able to write a Model Builder that creates a new child version from Pre-Production, selects records to be archived, appends them to the historical feature class, deletes these same records from the regular feature class and then running a reconcile with the option option �??Post Version after Reconcile�?� checked it works propagates all the updates for the child to the parent.But if I uncheck this option �??Post Version after Reconcile�?� in the Reconcile box and I run a POST TO Pre-Produciton I get an error message.
What does not work is adding a post box after the reconcile in ModelBuilder, it always fails, why?This is the error I got :Error 000533: the version can not be posted to the reconcile version. Reconcile must be performed before the post operation has been done.
# Process: Create Version... gp.CreateVersion_management(xyz_SDE_93_sde__2_, "SURADMIN.Pre_Prod", "Historical", "PUBLIC") # Process: Make Feature Layer... gp.MakeFeatureLayer_management(W_Source, Source_Layer, "STATUS = 'GIS Completed'", xyz_SDE_93_sde, ".....") # Process: Append... gp.Append_management("Source_Layer", W_Historical__2_, "TEST", "", "") # Process: Reconcile Version... gp.ReconcileVersion_management(xyz_SDE_93_sde, "LocalVersion.Historical", "SURADMIN.Pre_Prod", "BY_OBJECT", "FAVOR_TARGET_VERSION", "LOCK_AQUIRED", "NO_ABORT", "POST")
