<Context docBase="geocarto54" path="/geocarto54" debug="0" reloadable="true" crossContext="true"> <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource" driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver" url="jdbc:sqlserver://CARTOSQL:1433;databaseName=carto54" user="admin" password="admin" maxActive="20" maxIdle="10" maxWait="-1" /> </Context>
Please post back for the group if you were able to correct the JDBC issue
2 mai 2011 16:19:39 com.esri.gpt.control.webharvest.engine.TaskQueue next ATTENTION: [SYNCHRONIZER] Error fetching next task org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (The TCP/IP connection to the host CARTOSQL, port 1431 has failed. Error: Connection refused: connect. Please verify the connection properties and check that a SQL Server instance is running on the host and accepting TCP/IP connections at the port, and that no firewall is blocking TCP connections to the port.) at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549) at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388) at org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044) at com.esri.gpt.framework.sql.DatabaseReference.openJndiConnection(Unknown Source) at com.esri.gpt.framework.sql.DatabaseReference.openConnection(Unknown Source) at com.esri.gpt.framework.sql.ManagedConnection.<init>(Unknown Source) at com.esri.gpt.framework.sql.ManagedConnections.returnConnection(Unknown Source) at com.esri.gpt.framework.sql.ConnectionBroker.returnConnection(Unknown Source) at com.esri.gpt.framework.sql.BaseDao.returnConnection(Unknown Source) at com.esri.gpt.catalog.harvest.jobs.HjGetNextRequest.execute(Unknown Source) at com.esri.gpt.control.webharvest.engine.TaskQueue.next(Unknown Source) at com.esri.gpt.control.webharvest.engine.Worker.next(Unknown Source) at com.esri.gpt.control.webharvest.engine.Worker.execute(Unknown Source) at com.esri.gpt.control.webharvest.engine.WorkerBase.run(Unknown Source) at java.lang.Thread.run(Unknown Source) Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The TCP/IP connection to the host CARTOSQL, port 1431 has failed. Error: Connection refused: connect. Please verify the connection properties and check that a SQL Server instance is running on the host and accepting TCP/IP connections at the port, and that no firewall is blocking TCP connections to the port. at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:130) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1195) at com.microsoft.sqlserver.jdbc.SQLServerConnection.loginWithoutFailover(SQLServerConnection.java:1054) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:758) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:842) at org.apache.tomcat.dbcp.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38) at org.apache.tomcat.dbcp.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582) at org.apache.tomcat.dbcp.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556) at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545) ... 14 more
<!-- Context configuration file for the Geoportal Web App --> <Context docBase="geocarto54" path="/geocarto54" debug="0" reloadable="true" crossContext="true"> <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource" driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver" url="jdbc:sqlserver://CARTOSQL:1431;databaseName=carto54" user="admincarto54" password="xyz" maxActive="20" maxIdle="10" maxWait="-1" /> </Context>
<!-- Context configuration file for the Geoportal Web App --> <Context docBase="geoportal" path="/geoportal" debug="0" reloadable="true" crossContext="true"> <Resource name="jdbc/gpt" auth="Container" type="javax.sql.DataSource" driverClassName="sun.jdbc.odbc.JdbcOdbcDriver" url="jdbc:odbc:geoportal" user="admincarto54" password="xyz" maxActive="20" maxIdle="10" maxWait="-1" /> </Context>
I tryed Dbvizualizer and with this software, I can connect me with tcp port 1354.But with geoportal, this error appear :Cannot create PoolableConnectionFactory (�?chec de l'ouverture de session de l'utilisateur ''. L'utilisateur n'est pas associé à une connexion SQL Server approuvée.) I use exactly the same user, password, database, driver ... I don't understand why it work with dbvizualizer but not SQL Server ...
This would indicate that the username logon is not allowed/configured to remotely log in to your SQL Server.
Thank you, It' OK
