I am developing a web app using JS api 4.15. The clients really want to have multiple layerlists where each contains a different category of data. I was excited to find the example in this thread Multiple LayerLists In Web App but while it works in 4.12, I can't figure out how to get it to work in 4.15. Has anyone successfully adapted this code to work in 4.15 or can anyone help me with this?
Thank you Christian for pointing me in the right direction! I have figured it out and am happy with the results. If anyone else is interested, swap the view.when function in the previous code sample with the function shown is this code snippet.
<SPAN class="keyword token">var</SPAN> layerListUSA <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"listDiv1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerListCensus <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"listDiv2"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerListUSA<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> elementsUSA <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementsByClassName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'esri-layer-list__item esri-layer-list__item--has-children'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> elementsUSA<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>display <SPAN class="operator token">=</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>layerListCensus<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> elementsCensus <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementsByClassName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'esri-layer-list__item esri-layer-list__item--has-children'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> elementsCensus<SPAN class="punctuation token">[</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>display <SPAN class="operator token">=</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Tamia Rudnicky,
I'm trying to adapt your code for my use case.
I'm having trouble hiding layers in my second layer list. It seems i'm only able to manipulate the first layer list.
What am I doing wrong?
Here is my code:
<SPAN class="doctype token"><!DOCTYPE html></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">charset</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>initial-scale<SPAN class="punctuation token">=</SPAN>1,maximum-scale<SPAN class="punctuation token">=</SPAN>1,user-scalable<SPAN class="punctuation token">=</SPAN>no<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Tahoe Imagery Swipe<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>title</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>link</SPAN> <SPAN class="attr-name token">rel</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>stylesheet<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">href</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.14/esri/themes/light/main.css<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="punctuation token">/></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>https://js.arcgis.com/4.14/<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="language-css style token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="selector token">html, body, #viewDiv</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">margin</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 100%<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.overlay</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN>fixed<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">height</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN>table<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="token function">rgba</SPAN><SPAN class="punctuation token">(</SPAN>0,0,0,0.8<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-webkit-animation</SPAN><SPAN class="punctuation token">:</SPAN> splash 20s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">animation</SPAN><SPAN class="punctuation token">:</SPAN> splash 20s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.overlay-inner</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN>table-cell<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">vertical-align</SPAN><SPAN class="punctuation token">:</SPAN>middle<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">text-align</SPAN><SPAN class="punctuation token">:</SPAN>center<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.title</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="property token">align-content</SPAN><SPAN class="punctuation token">:</SPAN> center<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.message</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/* border:1px solid #6e6e6e;*/</SPAN> <SPAN class="property token">border-radius</SPAN><SPAN class="punctuation token">:</SPAN> 4px<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgba</SPAN><SPAN class="punctuation token">(</SPAN>102,128,168, 0.6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN>inline-block<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">vertical-align</SPAN><SPAN class="punctuation token">:</SPAN>middle<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN>50%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">text-align</SPAN><SPAN class="punctuation token">:</SPAN>center<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Avenir Next W00"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">color</SPAN><SPAN class="punctuation token">:</SPAN> #f9f9f9<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.active</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> #6680a8<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">color</SPAN><SPAN class="punctuation token">:</SPAN> #4c4c4c<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.overlay-wrap</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN>fixed<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">right</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">z-index</SPAN><SPAN class="punctuation token">:</SPAN>99<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.overlay-wrap .hide</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN>absolute<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">right</SPAN><SPAN class="punctuation token">:</SPAN>20px<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/* border:1px solid #6e6e6e;*/</SPAN> <SPAN class="property token">border-radius</SPAN><SPAN class="punctuation token">:</SPAN> 2px<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">background</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="token function">rgba</SPAN><SPAN class="punctuation token">(</SPAN>102,128,168, 0.6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN>inline-block<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">text-align</SPAN><SPAN class="punctuation token">:</SPAN>middle<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-family</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Avenir Next W00"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">color</SPAN><SPAN class="punctuation token">:</SPAN>#f9f9f9<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">padding</SPAN><SPAN class="punctuation token">:</SPAN>2px<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">font-size</SPAN><SPAN class="punctuation token">:</SPAN>100%<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">z-index</SPAN><SPAN class="punctuation token">:</SPAN>2<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">cursor</SPAN><SPAN class="punctuation token">:</SPAN>pointer<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-webkit-animation</SPAN><SPAN class="punctuation token">:</SPAN>15s fadein 2s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-moz-animation</SPAN><SPAN class="punctuation token">:</SPAN>15s fadein 2s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-ms-animation</SPAN><SPAN class="punctuation token">:</SPAN>15s fadein 2s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">animation</SPAN><SPAN class="punctuation token">:</SPAN>15s fadein 2s forwards<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#hide</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN>absolute<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">.overlay2</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN>absolute<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-webkit-transition</SPAN><SPAN class="punctuation token">:</SPAN>all 2s<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-moz-transition</SPAN><SPAN class="punctuation token">:</SPAN>all 2s<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">-ms-transition</SPAN><SPAN class="punctuation token">:</SPAN>all 2s<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">transition</SPAN><SPAN class="punctuation token">:</SPAN>all 2s <SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">#hide:checked ~ div,#hide:checked ~ div *, #hide:checked + label</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">right</SPAN><SPAN class="punctuation token">:</SPAN>auto<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN> <SPAN class="property token">pointer-events</SPAN><SPAN class="punctuation token">:</SPAN>none<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-webkit-keyframes</SPAN> splash</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-moz-keyframes</SPAN> splash</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-ms-keyframes</SPAN> splash</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@keyframes</SPAN> splash</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">;</SPAN><SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-webkit-keyframes</SPAN> fadein</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-moz-keyframes</SPAN> fadein</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@-ms-keyframes</SPAN> fadein</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em <SPAN class="punctuation token">}</SPAN> <SPAN class="atrule token"><SPAN class="rule token">@keyframes</SPAN> fadein</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="selector token">0%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN> 0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">20%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">;</SPAN><SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">60%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>1<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">99%</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>10px<SPAN class="punctuation token">}</SPAN> <SPAN class="selector token">100%</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="property token">opacity</SPAN><SPAN class="punctuation token">:</SPAN>0<SPAN class="punctuation token">;</SPAN><SPAN class="property token">top</SPAN><SPAN class="punctuation token">:</SPAN>-999em<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>style</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/TileLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/MapImageLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Swipe"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Expand"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/query"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/core/watchUtils"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> TileLayer<SPAN class="punctuation token">,</SPAN> MapImageLayer<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">,</SPAN> Swipe<SPAN class="punctuation token">,</SPAN> Expand<SPAN class="punctuation token">,</SPAN>query<SPAN class="punctuation token">,</SPAN> watchUtils<SPAN class="punctuation token">,</SPAN> domStyle<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">const</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"satellite"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">const</SPAN> fortyLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://maps.trpa.org/server/rest/services/1940_Imagery/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN> maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>fortyLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">const</SPAN> sixtynineLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://maps.trpa.org/server/rest/services/1969_Imagery/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN> maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>sixtynineLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">const</SPAN> fifteenLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"https://maps.trpa.org/server/rest/services/2015_Imagery/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN> maxScale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3000</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>fifteenLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// const eighteenLayer = new TileLayer({</SPAN> <SPAN class="comment token">// url: "https://maps.trpa.org/server/rest/services/2015_Imagery/MapServer",</SPAN> <SPAN class="comment token">// maxScale: 3000</SPAN> <SPAN class="comment token">// });</SPAN> <SPAN class="comment token">// map.add(eighteenLayer);</SPAN> <SPAN class="keyword token">const</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">120.01</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">38.93</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">15</SPAN><SPAN class="punctuation token">,</SPAN> constraints<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> maxZoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">17</SPAN><SPAN class="punctuation token">,</SPAN> minZoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> lList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>lList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> elementsLeftList <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementsByClassName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'esri-layer-list__item esri-layer-list__item--has-children'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> elementsLeftList<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>display <SPAN class="operator token">=</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>elementsLeftList<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>lList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-left"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> rList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN>rList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'operationalItems.length'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> elementsRightList <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementsByClassName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'esri-layer-list__item esri-layer-list__item--has-children'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> elementsRightList<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>display <SPAN class="operator token">=</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">;</SPAN> elementsRightList<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>style<SPAN class="punctuation token">.</SPAN>display <SPAN class="operator token">=</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">;</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>elementsRightList<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>rList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"bottom-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// create a new Swipe widget</SPAN> <SPAN class="keyword token">const</SPAN> swipe <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Swipe</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> leadingLayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>fortyLayer<SPAN class="punctuation token">,</SPAN> sixtynineLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> trailingLayers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>fifteenLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> position<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="comment token">// set position of widget to 35%</SPAN> view<SPAN class="punctuation token">:</SPAN> view <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// add swipe to view</SPAN> view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>swipe<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewDiv<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>overlay-wrap<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>input</SPAN> <SPAN class="attr-name token">type</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>checkbox<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>hide<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">id</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>hide<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>label</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>hide<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">for</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>hide<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>X<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>label</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>overlay2<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>overlay<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>overlay-inner<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>div</SPAN> <SPAN class="attr-name token">class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>message<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>h2</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Historic Image Swipe<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>h2</SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Use this map to <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN>SWIPE<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>b</SPAN><SPAN class="punctuation token">></SPAN></SPAN> between the hisotric image layers. Toggle them off to view the most recent imagery underneath.<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>p</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>div</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>body</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Tamia Rudnicky I can't provide a ready to use solution right off the cuff right now, but another thing I'd suggest is to try it with "old school" DOM Manipulation - selecting the <li> elements of the layerlist by class and remove exactly those you don't wanna have to show up. Do this for every layerlist you have in your application.
<SPAN class="keyword token">var</SPAN> elements <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementByClassName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'classnameoflayerlistitem'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> elements<SPAN class="punctuation token">[</SPAN>indextoremove<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>parentNode<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeChild</SPAN><SPAN class="punctuation token">(</SPAN>elements<SPAN class="punctuation token">[</SPAN>indextoremove<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
Hi Christian,
Thank you for the suggestion. I have tried to play with the listMode before but it hides the layer in both LayerLists. Your method gave me a different approach but unfortunately it didn't work. In my test example below I want the USALayer to display in the layerlist on the left and the CensusLayer to show on the right.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1, maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>LayerList widgets testing <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.15</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.15/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> overflow<SPAN class="punctuation token">:</SPAN> hidden<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">.</SPAN>divClass <SPAN class="punctuation token">{</SPAN> width<SPAN class="punctuation token">:</SPAN> 240px<SPAN class="punctuation token">;</SPAN> border<SPAN class="punctuation token">:</SPAN> 2px solid #00467F<SPAN class="punctuation token">;</SPAN> background<SPAN class="operator token">-</SPAN>color<SPAN class="punctuation token">:</SPAN> white<SPAN class="punctuation token">;</SPAN> border<SPAN class="operator token">-</SPAN>radius<SPAN class="punctuation token">:</SPAN> 10px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #listDiv1 <SPAN class="punctuation token">{</SPAN> position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN> top<SPAN class="punctuation token">:</SPAN> 30px<SPAN class="punctuation token">;</SPAN> left<SPAN class="punctuation token">:</SPAN> 55px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> #listDiv2 <SPAN class="punctuation token">{</SPAN> position<SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN> top<SPAN class="punctuation token">:</SPAN> 30px<SPAN class="punctuation token">;</SPAN> right<SPAN class="punctuation token">:</SPAN> 40px<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.15/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN> <SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GroupLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/MapImageLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/LayerList"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>Map<SPAN class="punctuation token">,</SPAN> MapView<SPAN class="punctuation token">,</SPAN> GroupLayer<SPAN class="punctuation token">,</SPAN> MapImageLayer<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> USALayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"US Sample Data"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> censusLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapImageLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> url<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer"</SPAN><SPAN class="punctuation token">,</SPAN> title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"US Sample Census"</SPAN><SPAN class="punctuation token">,</SPAN> visible<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">98.5795</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">39.8282</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> map<SPAN class="punctuation token">:</SPAN> map <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addMany</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>USALayer<SPAN class="punctuation token">,</SPAN> censusLayer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerListUSA <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"listDiv1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> layerListCensus <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"listDiv2"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> hideInDiv1 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"US Sample Census"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> hideInDiv2 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"US Sample Data"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> itemsUSA <SPAN class="operator token">=</SPAN> layerListUSA<SPAN class="punctuation token">.</SPAN>operationalItems<SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> j <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> j <SPAN class="operator token"><</SPAN> itemsUSA<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> j<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>hideInDiv1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>itemsUSA<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">>=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> itemsUSA<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hide"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">var</SPAN> itemsCensus <SPAN class="operator token">=</SPAN> layerListCensus<SPAN class="punctuation token">.</SPAN>operationalItems<SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> j <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> j <SPAN class="operator token"><</SPAN> itemsCensus<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> j<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>hideInDiv2<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>itemsCensus<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">>=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> itemsCensus<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hide"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>hideInDiv1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>itemsCensus<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">>=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> itemsCensus<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">"show"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"listDiv1"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"divClass"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"listDiv2"</SPAN> <SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"divClass"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The Layerlist has a Property called "operationalItems" which gives you access to the Layers displayed in the Layerlist. You can set the listMode property to "hide" and the Layer won't be shown in the Layerlist.
myfirstlayerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/* ################################################# OPTIONAL WIDGET SETTINGS var items includes all 4 layers which could be visible on the Layer Widget. Set the listMode property to: "show" - layer visible "hide" - layer not visible ################################################# */</SPAN> <SPAN class="keyword token">var</SPAN> hiddenLayer <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"insert title of layer HERE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"optional second title"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> items <SPAN class="operator token">=</SPAN> myfirstlayerList<SPAN class="punctuation token">.</SPAN>operationalItems<SPAN class="punctuation token">.</SPAN>items<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> j <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> j <SPAN class="operator token"><</SPAN> items<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> j<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>hiddenLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">indexOf</SPAN><SPAN class="punctuation token">(</SPAN>items<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>title<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">>=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> items<SPAN class="punctuation token">[</SPAN>j<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>layer<SPAN class="punctuation token">.</SPAN>listMode <SPAN class="operator token">=</SPAN> <SPAN class="string token">"hide"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
The idea is that the code iterates through the hiddenLayer List in which you can put any FeatureLayer you wish to hide and if the given Layer is inside of the operationalItems it will set the listMode of its layer to hide.
Layer | ArcGIS API for JavaScript 4.15
