preload???Determines if the widget is "activated" when the Viewer application initially opens. It can have one of two states: open or minimized. Widgets, by default, are loaded on demand, that is, not preloaded at all.
I need to set a widget to be preloaded as a minimized state. In the config.xml, it is currently preload="open", I want to set it as preload="mini". But flexviewer does not recognize the key word �??mini�?� and it does not work. Is there any method I can set the initial state as minimized state, instead of fully open state? Thanks a lot!
