Hi - I am trying to follow the help detailed here:
Specify the default token expiration time—Portal for ArcGIS (10.6) | ArcGIS Enterprise
but none of the steps here:
Seem to work. That is, there is no 'Update' method at the bottom of the page, nor do I see a Max Token Expiation Minutes field to update
David
Hello David,
So in that case go ahead and use the updated API for this in the form of https://webadaptorhost.domain.com/webadaptorname/sharing/rest. Once logged in you will have to navigate back to https://webadaptorhost.domain.com/webadaptorname/sharing/rest as it will redirect you to https://webadaptorhost.domain.com/portal/sharing/rest/community/users/portaladmin. You will be able to see Portals -> Self -> Update.
When you navigated to the sharing endpoint did you login? In the top right of the page there should be blue text that reads "login." Use credentials that have administrative rights to the Portal and you should see the update button.
I did but I get a nasty warning that says:
Did you mean /sharing/rest/...?
You are using an unsupported version of this API located at https://xyz.xyz.net/portal/sharing. Avoid using and/or developing with this unsupported version. There are pitfalls in doing so and no advantages over using the released and supported version of the API, which is logically equivalent. The supported version is located at https://xyz.xyz.net/portal/sharing/rest/.
and then when I do login I do not see just an 'update' resource or supported operation:
Child Resources: User Notifications User Tags User Invitations User Properties Linked Users
Supported Operations: Update User Reassign User Delete User Set User Properties Forgot Password Reset Invalidate Sessions Provisioned Listings Link User Unlink User
Related Resources: User Content
Sorry, I was able to navigate through to find the update operation by clicking on my org id and so can update the max token lifespan. I'll go ahead and consider this answered, but the large red-highlighted warning still does appear. Are there plans to allow these operations:
Child Resources: Users Resources Approved Apps Invitations Roles Check ServiceName . . .
Supported Operations: Update . . . .
without the warnings?
Great thanks will do. Hopefully 10.6.1 or 10.6.2 will have an update on this so we don't get the warnings . . .
