Could you tell us, which settings worked for you?
added solution, that worked for us:
We used the standard COM settings with 9600 baud and nothing else changed on the COM-Port settings (so 8 databits, parity NONE and stopbits 1) in the rangefinder prefrences. Activated "Automatically activate" and "Feature Capture Button" with any button.
The trick is to fire the event from the vector before setting the point in the map. Tap the "Point"-button on the edit toolbar, then push both buttons on the vector and the Point/Vertex dialog box opens automatically with the inserted values for bearing, slope distance and inclination that were sent from the vector. Add the position value and your attributes and save the point feature.
I have Leica Vector Range finder. I tested the port communication and I am receiving a signal. However - ArcPad 10.0.3 is not seeing anything in debug mode. I have tried 9600 and 4800. Also tried the correct range finder extension. Any suggestions would be appreciated greatly.
