Is it possible to save a track view that only shows tracks that are older than 24 hrs? I want one track view that shows tracks within 24hrs, and one that shows the tracks that are between 24 and 72 hrs old, but can't seem to get it.
Yes, use the "Location Timestamp" field, which represents the time when a point was recorded by the device.
A filter in the map viewer should be sufficient, that would be on the 'Location Timestamp' field correct?
Thanks, I had forgotten that it was possible to do relative filters now.
Hi Julia,
Is it sufficient to filter the Track View in Map Viewer by applying a relative date filter? Or, do you really need that filter applied to the view no matter which map it's in?
It's possible to do both, but the second scenario requires more manual configuration that is not available in Track Viewer. I can provide steps for that if you'd like.
