I try new geoprocessing widget in samples but got error ..http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=apps/config-geoprocessing.xml
I've migrated from 2.3.1 to 2.4 by copying XML files. The viewer appears to be working fine, except that the busy "clock" icon won't go away.Nate S
Today we released version 2.4 of both ArcGIS API for Flex and ArcGIS Viewer for Flex.There are lots of highlights to both Flex API and Flex Viewer. Check out the What's New in the updated help for the full list of changes. Here's my top-10 for the Viewer 2.4:New Geoprocessing widget that works with almost any geoprocessing task.Clustering of points from feature layers. Configuring definition expression on sublayers within a layer of type="dynamic" (an ArcGIS Dynamic map Service). Being able to set the widget size in the configuration file.KML Layer - the <layer> tag supports type="kml".Support for four new locales have been added - Arabic, Brazilian Portuguese, Italian and Russian - to the existing six locales.Initial "view" of Search and Locate widget can be set in widget configuration file.Works better with Adobe Flex 4.5 SDK.Widgets can be centered using new verticalcenter and horizontalcenter.Bug fixes:Color of hyperlinks in popup windows remain the same even after clicking the link.Multiple bug fixes related to widget layout locations and run-away widgets. Widgets can be place anywhere even when the overview map widget is open. Floating and vertical layouts don't experience run-away widgets.Overview map widget can be placed in any corner.Tip: If you don't see the new pages, try emptying your browser cache, or wait a little for all our web servers to clear their caches...http://help.arcgis.com/en/webapps/flexviewer/help/#/What_s_new_in_2_4/01m300000011000000/
I am not seeing how to configure the Clustering on feature layers, am I overlooking something ?
Compiling the source code [for ArcGIS Viewer for Flex] requires Adobe Flex 4.1 or above. This is to support Arabic and other right-to-left locales. Note that the API itself still works with 4.0, 4.1 as well as 4.5.
In version 2.4 of the Viewer, Adobe Flex 4.1 SDK is the minimum SDK version to compile with.
Adobe Flex SDK versionsThe only currently supported software development kit (SDK) version is Adobe Flex SDK 4.0. For detailed Flex framework system requirements, read the most up-to-date Flex SDK system requirements by Adobe.
<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Read more about ArcGIS Viewer for Flex - http://links.esri.com/flexviewer // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <title>City of Arkansas City</title> <subtitle>GIS Webmap</subtitle> <logo>assets/images/ArkCitylogosmall.png</logo> <style> <!-- Black Gold --> <!--<colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>--> <!--Cobalt Blue--> <colors>0xCEE7F4,0x39628C,0x355D89,0x294867,0xCEE7F4</colors> <!--Desert Sand--> <!--<colors>0x4C2600,0xFFEDB8,0xB2AD81,0x6F6750,0x4C2600</colors>--> <!--Graphite Gray--> <!--<colors>0xCCCCCC,0x777777,0x555555,0x333333,0xCCCCCC</colors>--> <!--Sage Green--> <!--<colors>0x333333,0xAFCFAF,0xFFFFAB,0xEAEA9D,0x333333</colors>--> <!--Sky Blue--> <!--<colors>0x444444,0xEBF4FF,0xEBF4FF,0xDEEBFF,0x444444</colors>--> <alpha>0.8</alpha> </style> <!-- replace the following url with your own geometryservice --> <geometryservice url="http://gis-server/arcgis/services/Geometry/GeometryServer" /> <!-- UI elements --> <widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/> <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/> <widget right="20" top="55" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <widget left="3" bottom="3" config="widgets/Coordinate/CoordinateWidget.xml" url="widgets/Coordinate/CoordinateWidget.swf"/> <map wraparound180="true" initialextent="-10803160 4447456 -10801480 4448154" fullextent="-10854000 4445400 -10727000 4503000" top="40"> <basemaps> <layer label="Streets" type="tiled" visible="true" url="http://gis-server/ArcGIS/rest/services/StreetsBase/MapServer"/> <layer label="Aerial" type="tiled" visible="false" url="http://gis-server/ArcGIS/rest/services/Aerial/MapServer"/> <layer label="Topo" type="tiled" visible="false" url="http://gis-server/ArcGIS/rest/services/Topographic/MapServer"/> </basemaps> <operationallayers> <layer label="Demographics" type="tiled" visible="false" alpha="0.5" url="http://server.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Median_Household_Income/MapServer"> <sublayer id="1" popupconfig="popups/PopUp_Demographics_BlockGroups.xml"/> <sublayer id="2" popupconfig="popups/PopUp_Demographics_Tracts.xml"/> <sublayer id="3" popupconfig="popups/PopUp_Demographics_Counties.xml"/> <sublayer id="4" popupconfig="popups/PopUp_Demographics_States.xml"/> </layer> <layer label="Addresses" type="dynamic" visible="true" url="http://gis-server/ArcGIS/rest/services/Addresses-Streets/MapServer"/> <layer label="Utilities" type="dynamic" visible="false" url="http://gis-server/ArcGIS/rest/services/Utilities/MapServer"/> <layer label="Parcels" type="dynamic" visible="true" url="http://gis-server/ArcGIS/rest/services/Parcels/MapServer"> <sublayer id="16" popupconfig="popups/PopUp_parcels.xml"/> </operationallayers> </map> <!-- widgets organized into widget containers that manage close/open etc --> <!-- supported layout property options: horizontal(default)|float|vertical|fix--> <widgetcontainer layout="float"> <widget label="Bookmarks" left="430" top="90" icon="assets/images/i_bookmark.png" config="widgets/Bookmark/BookmarkWidget.xml" url="widgets/Bookmark/BookmarkWidget.swf"/> <widget label="Find an address" left="100" top="90" preload="open" icon="assets/images/i_target.png" config="widgets/Locate/LocateWidget_ArkCity.xml" url="widgets/Locate/LocateWidget.swf"/> <!--<widget label="Search" left="80" top="280" icon="assets/images/i_search.png" config="widgets/Search/SearchWidget_Louisville.xml" url="widgets/Search/SearchWidget.swf"/> --> <widget label="Draw and Measure" left="60" top="400" icon="assets/images/i_draw2.png" config="widgets/Draw/DrawWidget.xml" url="widgets/Draw/DrawWidget.swf"/> <widget label="Print" left="390" top="400" icon="assets/images/i_print.png" config="widgets/myPrint/myPrintWidget.xml" url="widgets/myPrint/myPrintWidget.swf"/> <widget label="Street View" icon="assets/images/i_gsv.png" config="widgets/FrStreetView/FrStreetView.xml" url="widgets/FrStreetView/FrStreetView.swf"/> <widget label="Layer List" preload="open" icon="assets/images/i_layers.png" config="widgets/LayerList/LayerListWidget.xml" url="widgets/LayerList/LayerListWidget.swf"/> <!-- <widget label="My first widget" icon="assets/images/i_widget.png" config="widgets/Samples/HelloWorld/HelloWorldWidget.xml" url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/> --> </widgetcontainer> </configuration>
<?xml version="1.0" ?> <!-- //////////////////////////////////////////////////////////////////////////////// // // Read more about ArcGIS Viewer for Flex - http://links.esri.com/flexviewer // //////////////////////////////////////////////////////////////////////////////// --> <configuration> <title>City of Arkansas City</title> <subtitle>GIS Webmap</subtitle> <logo>assets/images/ArkCitylogosmall.png</logo> <style> <!-- Black Gold --> <!--<colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>--> <!--Cobalt Blue--> <colors>0xCEE7F4,0x39628C,0x355D89,0x294867,0xCEE7F4</colors> <!--Desert Sand--> <!--<colors>0x4C2600,0xFFEDB8,0xB2AD81,0x6F6750,0x4C2600</colors>--> <!--Graphite Gray--> <!--<colors>0xCCCCCC,0x777777,0x555555,0x333333,0xCCCCCC</colors>--> <!--Sage Green--> <!--<colors>0x333333,0xAFCFAF,0xFFFFAB,0xEAEA9D,0x333333</colors>--> <!--Sky Blue--> <!--<colors>0x444444,0xEBF4FF,0xEBF4FF,0xDEEBFF,0x444444</colors>--> <alpha>0.8</alpha> </style> <!-- replace the following url with your own geometryservice --> <geometryservice url="http://gis-server/arcgis/services/Geometry/GeometryServer" /> <!-- UI elements --> <widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/> <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/> <widget right="20" top="55" config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <widget left="3" bottom="3" config="widgets/Coordinate/CoordinateWidget.xml" url="widgets/Coordinate/CoordinateWidget.swf"/> <map wraparound180="true" initialextent="-10803160 4447456 -10801480 4448154" fullextent="-10854000 4445400 -10727000 4503000" top="40"> <basemaps> <layer label="Streets" type="tiled" visible="true" url="http://gis-server/ArcGIS/rest/services/StreetsBase/MapServer"/> <layer label="Aerial" type="tiled" visible="false" url="http://gis-server/ArcGIS/rest/services/Aerial/MapServer"/> <layer label="Topo" type="tiled" visible="false" url="http://gis-server/ArcGIS/rest/services/Topographic/MapServer"/> </basemaps> <operationallayers> <layer label="Demographics" type="tiled" visible="false" alpha="0.5" url="http://server.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_Median_Household_Income/MapServer"> <sublayer id="1" popupconfig="popups/PopUp_Demographics_BlockGroups.xml"/> <sublayer id="2" popupconfig="popups/PopUp_Demographics_Tracts.xml"/> <sublayer id="3" popupconfig="popups/PopUp_Demographics_Counties.xml"/> <sublayer id="4" popupconfig="popups/PopUp_Demographics_States.xml"/> </layer> <layer label="Addresses" type="dynamic" visible="true" url="http://gis-server/ArcGIS/rest/services/Addresses-Streets/MapServer"/> <layer label="Utilities" type="dynamic" visible="false" url="http://gis-server/ArcGIS/rest/services/Utilities/MapServer"/> <layer label="Parcels" type="dynamic" visible="true" url="http://gis-server/ArcGIS/rest/services/Parcels/MapServer"> <sublayer id="16" popupconfig="popups/PopUp_parcels.xml"/> </layer> </operationallayers> </map> <!-- widgets organized into widget containers that manage close/open etc --> <!-- supported layout property options: horizontal(default)|float|vertical|fix--> <widgetcontainer layout="float"> <widget label="Bookmarks" left="430" top="90" icon="assets/images/i_bookmark.png" config="widgets/Bookmark/BookmarkWidget.xml" url="widgets/Bookmark/BookmarkWidget.swf"/> <widget label="Find an address" left="100" top="90" preload="open" icon="assets/images/i_target.png" config="widgets/Locate/LocateWidget_ArkCity.xml" url="widgets/Locate/LocateWidget.swf"/> <!--<widget label="Search" left="80" top="280" icon="assets/images/i_search.png" config="widgets/Search/SearchWidget_Louisville.xml" url="widgets/Search/SearchWidget.swf"/> --> <widget label="Draw and Measure" left="60" top="400" icon="assets/images/i_draw2.png" config="widgets/Draw/DrawWidget.xml" url="widgets/Draw/DrawWidget.swf"/> <widget label="Print" left="390" top="400" icon="assets/images/i_print.png" config="widgets/myPrint/myPrintWidget.xml" url="widgets/myPrint/myPrintWidget.swf"/> <widget label="Street View" icon="assets/images/i_gsv.png" config="widgets/FrStreetView/FrStreetView.xml" url="widgets/FrStreetView/FrStreetView.swf"/> <widget label="Layer List" preload="open" icon="assets/images/i_layers.png" config="widgets/LayerList/LayerListWidget.xml" url="widgets/LayerList/LayerListWidget.swf"/> <!-- <widget label="My first widget" icon="assets/images/i_widget.png" config="widgets/Samples/HelloWorld/HelloWorldWidget.xml" url="widgets/Samples/HelloWorld/HelloWorldWidget.swf"/> --> </widgetcontainer> </configuration>
Popup Problems in SFV2.4?Is there a maximum number of fields that can be displayed in a popups configuration? I need to display 15 fields, but anything more than 8 will only work on the first click. After the first click the info popup box is empty except for "title" and "zoom to"Any suggestions appreciatedThanksNed
See a fix for this here:http://forums.arcgis.com/threads/36513-2.4-PopUp-scrollbar-bug
Ned, In the Flex Viewer project right click on src folder in the Package Explorer and choose New > Package and for the name field put com.esri.ags.skins and then paste the PopUpRendererSkin.mxml into that Package/folder and run the Flex Viewer project again.
<components:AutoFontLabel id="bannerTitle" maxWidth="300" styleName="BannerTitle"/> <components:AutoFontLabel id="bannerSubtitle" maxWidth="300" styleName="BannerSubtitle" updateComplete="onSubTitleUpdateComplete(event)"/>
Is it possible for the users still to have the access to the help and examples for 2.3.X?
<initialview>text</initialview> <!-- valid values are text and graphical -->
