Do you have clientaccesspolicy.xml or crossdomain.xml file on your web server?
Private Sub layer_InitializationFailed(sender As Object, e As EventArgs) Dim layer As Layer = TryCast(sender, Layer) MessageBox.Show(String.Format("Layer '{0}' is currently unavailable. Error: {1}", layer.ID, layer.InitializationFailure.Message)) End Sub
awesome, thanks again.
Hi Varun,I ended up using the JavaScript API, which suited my client's purposes better. So I haven't used the Silverlight API at all since I posted this question.Sorry I can't help out.Good luck,Steve
