Hi everyoneThis might be a simple doubt. When opening a single .mxd, I can read correctly some properties of the layer, like Name and DataSourceType. When I try to access the FeatureClass, it always returns null. Checking the source inside ArcMap, the FeatureClass is there just as I want. So, why can't I read it programatically?Here's the relevant part of the code:
namespace WindowsApplication1
public partial class Form1 : Form
private IMapDocument pMapDocument = null;
private IMap pMap = null;
private IEnumLayer pEnumLayer = null;
private IFeatureLayer pFeatureLayer = null;
private IDataLayer2 pDataLayer = null;
private IDatasetName pDatasetName = null;
private IWorkspace pWorkspace = null;
private IWorkspaceName pWorkspaceName = null;
private IUID pUID = null;
private string p = "password";
public Form1()
InitializeComponent();
private void Form1_Shown(object sender, EventArgs e)
Application.DoEvents();
Start("", true);
private void Start(string sPath, bool inicializando)
bool saveInsideLayer = true;
int i;
string mxd;
IPropertySet pConnectionProperties = new PropertySetClass();
if (sPath == "")
saveInsideLayer = false;
sPath = @C:\layer.mxd;
try
pMapDocument = new MapDocumentClass();
if (pMapDocument.get_IsPresent(sPath))
pMapDocument.Open(sPath, "");
for (i = 0; i < pMapDocument.MapCount; i++)
pMap = pMapDocument.get_Map(i);
pUID = new UIDClass();
pUID.Value = "{E156D7E5-22AF-11D3-9F99-00C04F6BC78E}";
pEnumLayer = pMap.get_Layers((UID)pUID, true);
pEnumLayer.Reset();
pFeatureLayer = (IFeatureLayer)pEnumLayer.Next();
while (pFeatureLayer != null)
if (pFeatureLayer.DataSourceType.Contains("SDE"))
pDataLayer = (IDataLayer2)pFeatureLayer;
if (pDataLayer.DataSourceName is IDatasetName)
pDatasetName = (IDatasetName)pDataLayer.DataSourceName;
pWorkspaceName = pDatasetName.WorkspaceName;
if (pFeatureLayer.FeatureClass != null) // why never true?
pConnectionProperties = pFeatureLayer.FeatureClass.ExtensionProperties;
pWorkspaceName.ConnectionProperties = pConnectionProperties;
txtServidor.Text = pConnectionProperties.GetProperty("SERVER").ToString();
txtPorta.Text = pConnectionProperties.GetProperty("INSTANCE").ToString();
txtDatabase.Text = pConnectionProperties.GetProperty("DATABASE").ToString();
txtUsuario.Text = pConnectionProperties.GetProperty("USERNAME").ToString();
txtSenha.Text = pConnectionProperties.GetProperty("PASSWORD").ToString();
if (saveInsideLayer)
pMapDocument.ReplaceContents((IMxdContents)pMap);
pMapDocument.Save();
pMapDocument.Close();
catch (Exception ex)
throw new Exception("Unable to run the code", ex);
I'm working in Visual Studio 2005, and using an ArcInfo license for 9.3 version.Thanks for the attentionRodrigo Salvador
