I have a button that used to work fine in my non-AMD syntax. I have just two layers that I'd like to let the user turn on and off. I had a small function that would check the current visibility and toggle it on/off depending on its current state. //functions for turning layer on/off function toggleLayer(layerId) { var layer = app.map.getLayer(layerId); if (layer.visible) { layer.hide(); } else { layer.show(); } } I had the button defined as <button id="btnWICvendor" dojotype="dijit.form.Button" onClick="toggleLayer('venLayer')"> Click to Hide Sites</button>From my reading, it sounded like I should be adding the click listener to the button using dojo/on. Besides updating the button definition, I removed onClick and added this line into my code. But it doesn't look like I pass any argument with this method. registry.byId('btnWICvendor').on('click', toggleLayer);I thought this would be simple, but apparently not! What am I missing? I know I could use TOC, but that seems like overkill for this particular map.
