dear mmartin would you plzzzz send me a code snipit showing the complete block of code involved with your function you posted that works with 2.1v ?? ill be soooo thankful am trying to print a map with charts on it , which are picture markers i used the print function mentioned before in the thread but i only can se the graphics on the screen, but not on the printout paper could you plzzz help ?? its urgent regards to all
Exploring the Map2PF also... Curious about the new 2.1 and if you have any sample code written for this using the 2.1 you'd share? and did you use one namespace (pointing to 2.1) or two+ ?thanks!
Hello,I am trying to make a quick print page, or a page that simply shows the current map view with the relevant layers switched on and at the correct zoom level, or ideally a PDF.Can anyone here help me at all?I have looked at the Map2PDF and am unable to get this working. I have also followed what has been posted here and I get an HTML page with tiles all over the place. Can anyone post a quick dump of a print.css? Or anything useful at all.Many
Hi, How did you managed to print the map correctly?Thanks in advance,JM
<meta http-equiv="X-UA-Compatible" content="IE=7" />
I was finalyl able to get the print page to work. My next problem is I want the user to be able to right click the print page and be able to save it as an image. Currently though if the user does that it creates a seperate image for each tile, graphics layer, and legend.
