<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags"> <!-- ArcGIS API 3.1 --> <!-- Adobe SDK 4.6 --> <s:layout> <s:VerticalLayout paddingBottom="10" paddingLeft="10" paddingRight="10" paddingTop="10" gap="10"/> </s:layout> <fx:Script> <![CDATA[ import com.esri.ags.events.LayerEvent; import com.esri.ags.layers.supportClasses.LayerDefinition; import mx.collections.ArrayCollection; import mx.utils.StringUtil; import spark.events.IndexChangeEvent; [Bindable] private var definitions:Array; [Bindable] private var visibleLayers:ArrayCollection = new ArrayCollection([1]); [Bindable] private var landuseNames:ArrayCollection = new ArrayCollection( [ "GENERAL COMM. AND OFFICE", "INDUSTRIAL", "MULTI-FAMILY RESIDENTIAL", "PARKS, CEMETERIES, ETC.", "PUBLIC AND SEMI-PUBLIC", "SINGLE FAMILY RESIDENTIAL", "VACANT AND UNDEVELOPED" ] ); [Bindable] private var definitionConditions:ArrayCollection = new ArrayCollection( [ "like", "equals" ] ); [Bindable] private var defPart1:String = "LANDUSE_NAME"; protected function onSetDefinitionClick(event:MouseEvent):void { definitions = new Array(); // reset definitions var layerDefinition:LayerDefinition = new LayerDefinition(); layerDefinition.layerId = 1; // "LandUse" if (ddlConditions.selectedIndex == 1) // equals { layerDefinition.definition = StringUtil.substitute("{0} = '{1}'", defPart1, ddlValues.selectedItem); } else // like { layerDefinition.definition = StringUtil.substitute("{0} like '%{1}%'", defPart1, txtInput.text); } definitions.push(layerDefinition); // set cursor busy, and restore it after update ended map.cursorManager.setBusyCursor(); dynamicLayer.addEventListener(LayerEvent.UPDATE_END, function onUpdateEnd(event:LayerEvent):void { dynamicLayer.removeEventListener(LayerEvent.UPDATE_END, onUpdateEnd); map.cursorManager.removeBusyCursor(); }); // update layer dynamicLayer.refresh(); } protected function onClearDefinitionClick(event:MouseEvent):void { definitions = null; // remove definitions // set cursor busy, and restore it after update ended map.cursorManager.setBusyCursor(); dynamicLayer.addEventListener(LayerEvent.UPDATE_END, function onUpdateEnd(event:LayerEvent):void { dynamicLayer.removeEventListener(LayerEvent.UPDATE_END, onUpdateEnd); map.cursorManager.removeBusyCursor(); }); // update layer dynamicLayer.refresh(); } protected function onConditionChange(event:IndexChangeEvent):void { // switch inputs if (ddlConditions.selectedIndex == 0) //like { txtInput.visible = txtInput.includeInLayout = true; ddlValues.visible = ddlValues.includeInLayout = false; } else { txtInput.visible = txtInput.includeInLayout = false; ddlValues.visible = ddlValues.includeInLayout = true; } } ]]> </fx:Script> <s:HGroup verticalAlign="middle" gap="10"> <s:Label text="{defPart1}" /> <s:DropDownList id="ddlConditions" selectedIndex="0" dataProvider="{definitionConditions}" change="onConditionChange(event)"/> <s:TextInput id="txtInput" width="250" text="PUBLIC"/> <s:DropDownList id="ddlValues" selectedIndex="0" width="250" dataProvider="{landuseNames}" visible="false" includeInLayout="false" /> <s:Button label="Set definition" click="onSetDefinitionClick(event)" /> <s:Button label="No definition" click="onClearDefinitionClick(event)" /> </s:HGroup> <esri:Map id="map"> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer" layerDefinitions="{definitions}" visibleLayers="{visibleLayers}"/> </esri:Map> </s:Application>
Definition expression allows you to filter the features of individual layers in the exported map by specifying definition expressions for those layers.
