Dear all,
Please can someone assist with all and detited Hardware,software,network and service components needed to deploy GeoEvent server in defence precisely Airforce.
you can just itemise or list them out here.
Thank you.
Hi OKEKE ONYEDIKACHI JOSHUA
Here are some documentation links you may find useful in deploying a GeoEvent Server environment:
System requirements—ArcGIS GeoEvent Server (Windows) Installation Guide (10.6) | ArcGIS Enterprise
Installing GeoEvent Server—ArcGIS GeoEvent Server (Windows) Installation Guide (10.6) | ArcGIS Enterprise
These are the bare bones of what is required to successfully implement GeoEvent Server. If you follow all of these specifications, you should have no issue.
However, if you are looking for something a little more customized to your environment, as you noted with regards to Defense, you may need to contact Esri to see if you can inquire about a Professional Services engagement. We understand that deployment scenarios will vary and this will likely be your best option if you need advice specific to your environment.
Hope this helps.
Thanks for this, yes I will need something more customised to the environment here..
