Can you resave the maps and see if they are loaded in the app?ThanksRuss
Can you share one of the maps that are not displaying in your org?ThanksRuss
I'm also interested in hearing about any potential solutions because I seem to be having the same problem. Though in my case I'm just trying to get started with Collector. I published a feature service, created a web map in AGOL, made it editable and shared it with my organization but yet when I open Collector I get a message that says "You don't have any maps for use with Collector." Thanks for any insight.Also, Ken would you mind posting the link to the Community Art walk through you mentioned? I just tried searching and couldn't find it but maybe it would be helpful for me since I'm just getting started.
Make sure your maps have an editable feature service. This feature service can be hosted in ArcGIS Online or coming from an ArcGIS Server. Then you can log back into the app or refresh the map gallery in the app. Russ
Hey Russ
Almost exactly one year later, I'm experiancing the same problem. I have a map application with a host feature service that is editable for my AGOL group.
I was able to view and edit it with the Collector App, but when by mistake I removed the editing capabilities and later readded them to the hosted feature layer, the map disapeared permenantly from the app. Any ideas for solutions?
EDIT: It seems there ws n issue with concerning the rights on the hosted feature layers. Some layers were open to everybody, others were only for a certain group. I've recreted the app and now it works!
I was experiencing the same problem.
I think If you add a Hosted Feature Layer (with no editing capabilities) to a WebMap and then make it editable it will never be available from Collector (no matter whether it is editable or not). First you have to make the layer editable, and then add it to the WebMap, from that moment it will be available in Collector. At least it worked for me.
Juan,
If you add a Hosted Feature Layer (with no editing capabilities) to a WebMap and then make it editable, you need to re-save the webmap again to recognize the change of Hosted feature layer.
-Miaogeng
So how could you create an "offline" map if you don't need any editable features in it?
You need the editable features to make the map visible to Collector. An office map must consist of layers that have the capability to sync or export tiles.
Yes, this worked me for in the end. HOWEVER, in order to even see the option to post a shp zip as hosted service on AGOL one must have been granted publisher or admin status by an organization. I struggled with crazy-making app behavior for a whole day before I realized this (this will also unlock all sorts of analytical functionality on the map itself; plus you can make a map downloadable). Once turned into an admin, I could see this option. Here is the right workflow to do this:
1. I can't emphasize enough you need to become a publisher or admin in the organization. User will not do. See:
Publish hosted feature layers—ArcGIS Online Help | ArcGIS
2. Create a new web map in My Content. Don't add anything to this yet.
3. Post the zipfile(s) containing the shapefile files as admin in My Content.
4. In My Content, edit each service file so that they are editable.
5. Go to the web map and add the now editable layers. Important note: I found out Collector will not fetch a web map if only some of the layers are editable -even if one isn't, the map won't show. This is why ALL layer components added must be editable. This is crucial but nowhere disclosed.
6. Go back to My Content, select the web map and the layers and share them with a group, if appropriate. You need to do this in My Content because only there (as opposed to individual layer or map sharing) is there the option to specify access and edit capabilities for participants (as opposed to just access). Note: sharing with a group implies you have already created that group and invited members prior.
Note the following doesn't apply to AGOL.
Publishing feature services—Documentation | ArcGIS for Server
What's weird though, for 10 days before I was forced to troubleshoot this (my maps stopped showing in Collector suddenly), I had been able to post shapefiles normally (i.e. not as hosted services but as simple uploads) with user privileges and these showed in Collector fine.
I have a feature layer that is is hosted through AGOL and set to editable. The feature layer was created as results from Survey123. I tried adding the feature layer to a brand new AGOL map and saving the map, but the map does not show up in Collector. I tried saving a copy of the map with the layer and it still does not show up in Collector. I tried deleting the Collector app and re-downloading. The map still does not display in Collector. I am trying to integrate Survey123, Workforce, and Collector. It appears there is a disconnect with the web map created from Workforce to Collector, even though I have them linked through the settings in Workforce. All layers and maps are shared with a group, that I (the collector) am part of. Does anyone have any other suggestions on how to get the AGOL map to display in Collector?
I made some progress today in resolving my issue. I created a feature layer view of my feature layer. I then made a new AGOL map and added the feature layer view. This new map now shows up in Collector. While not ideal, this works. It is odd to me that the online map that is generated by the Workforce app. does not work in Collector - even though I have the integration settings configured and an editable layer. I tried replacing my feature layer with the feature layer view in my Workforce worker map. The Workforce worker map still doesn't show up in Collector. I don't think there's a way for me to change the source of the Workforce worker map to the new Collector map in the Workforce app. It only lets me configure the existing map. So I will have to maintain 3 online maps instead of 2.
