I have the same issue, I have VS2012 and ArcGIS 10.2 trial installed. I installed ArcGIS Runtime SDK for .NET version 10.2.4 and I still don't see the arcGIS templates under C#. Even if I select Framework 3.5 I don't get them.
Could you help? Thanks
For ArcGIS Runtime SDK for .NET 10.2.4:
https://developers.arcgis.com/net/desktop/guide/system-requirements.htm
Mohini
Thank you for your help:
I update VS2012 to Update 4. and re-installed the SDK. Under C# /Windows ( Framewotk 4.5 ) I have the ArcGIS Runtime 10.2.4 .NET Template. But this one is WPF template and I working with C# Windows Forms in the same way you ESRI shows in video: DS2010: Developing .NET Applications for ArcGIS Engine | ArcGIS Resource Center
where they are using MapControlApplication Template and in the Engine MapControl set the map document to show.
Could you help me? Thank you.
