Hi,I need to add new rule "Boundary Must Be Covered By Boundary of (Area - Area)" to my topology. So I run the tool - Topology - add rule to topology. But it give errer message. I can run same tool using other topology rules.Can anybody help me with it? This is bug in ArcGIS 10. Does any service pack solve this problem?Feng Tan
Hi, Does anyone know how to add the rule "Must Coincide With (Point-Point)" to a topology using AddRuleToTopology_management?I get the folowing error:ERROR 000800: The value is not a member of Must Not Have Gaps (Area) | Must Not Overlap (Area) | Must Be Covered By Feature Class Of (Area-Area) | Must Cover Each Other (Area-Area) | Must Be Covered By (Area-Area) | Must Not Overlap With (Area-Area) | Must Be Covered By Boundary Of (Line-Area) | Must Be Covered By Boundary Of (Point-Area) | Must Be Properly Inside (Point-Area) | Must Not Overlap (Line) | Must Not Intersect (Line) | Must Not Have Dangles (Line) | Must Not Have Pseudo-Nodes (Line) | Must Be Covered By Feature Class Of (Line-Line) | Must Not Overlap With (Line-Line) | Must Be Covered By (Point-Line) | Must Be Covered By Endpoint Of (Point-Line) | Boundary Must Be Covered By (Area-Line) | Boundary Must Be Covered By Boundary Of (Area-Area) | Must Not Self-Overlap (Line) | Must Not Self-Intersect (Line) | Must Not Intersect Or Touch Interior (Line) | Endpoint Must Be Covered By (Line-Point) | Contains Point (Area-Point) | Must Be Single Part (Line).Failed to execute (AddRuleToTopology).
