ArcGIS 10.6.1 Windows 10 64 bit.
I have a script tool that runs great until I process a certain table in a fgdb. On two tables it works just fine, and does what I want it to, but when I get to the third table it tosses this error in the script tool window:
File "W:\GIS\DataCleanUp.py", line 134, in <module>
main()
File "W:\GIS\DataCleanUp.py", line 131, in main
cleanUp()
File "W:\GIS\DataCleanUp.py", line 105, in cleanUp
edit.stopOperation()
SystemError: error return without exception set
The script is set up in different def's() ; my cleanUp() def is what fails:
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">cleanUp</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
edit <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>Editor<SPAN class="punctuation token">(</SPAN>ws<SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="token boolean">False</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#use False False: with undo,(False) multiuser mode(False)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>startOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
tableFields <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFields<SPAN class="punctuation token">(</SPAN>tableName<SPAN class="punctuation token">,</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'String'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> tableFields<SPAN class="punctuation token">:</SPAN>
fieldNames <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
fieldNames<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> fieldName <SPAN class="keyword token">in</SPAN> fieldNames<SPAN class="punctuation token">:</SPAN>
field <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>fieldName<SPAN class="punctuation token">]</SPAN>
field<SPAN class="punctuation token">.</SPAN>insert<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">'OBJECTID'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>tableName<SPAN class="punctuation token">,</SPAN>field<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> updateRows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">for</SPAN> updateRow <SPAN class="keyword token">in</SPAN> updateRows<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">if</SPAN> updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="operator token">==</SPAN> None<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">pass</SPAN>
<SPAN class="keyword token">elif</SPAN> <SPAN class="string token">"\n"</SPAN> <SPAN class="keyword token">in</SPAN> updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">:</SPAN>
updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>replace<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"\n"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">" ==> "</SPAN><SPAN class="punctuation token">)</SPAN>
updateRows<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN>updateRow<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Success: Updated OID:{} in table:{} field:{}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>tableName<SPAN class="punctuation token">,</SPAN>field<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN> Exception <SPAN class="keyword token">as</SPAN> err<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'{} {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Error: Unable to process {} {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>updateRow<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>field<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># =============================================================================</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopOperation<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
edit<SPAN class="punctuation token">.</SPAN>stopEditing<SPAN class="punctuation token">(</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'Closed edit session'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>It's called from main() and is the last in series of defs.
I write to a log file, but the errors I capture there are meaningless at best:
(1)The row contains a bad value. [SITENOTES]
(2)99 Safe for 1 sampler. Lots of human/dog activity. Easy to navigate
(3)Error: Unable to process 99 SITEVERIFY
(1) is the actual error from ArcGIS although I have no idea what record it fails on or why the [SITENOTES] field is noted
(2) is my error where I capture the the OID, and the contents of the field: so for whatever reason it's telling me that OID 99 has a [SITENOTES] field value of: Safe for 1 sampler. Lots of human/dog activity. Easy to navigate
(3) is one of my error captures, and is baffling as well, since the SITEVERIFY field isn't even considered for OID 99 or any other.
Looking at the error that appears in script tool window, it complains about line 105 which is shown as line 33 in the cleanUp() def shown above. My logic is to open the edit session, run the update cursor, and then close the edit session. However, notice line 35 above: it never does close the edit session.
After searching on SystemError: error return without exception set I don't quite understand what it means and/or how to mitigate for it. Again, the weird thing about this mess is the script tool runs just fine on two other tables. It finds the newline character '\n' and replaces it with '==>' without a problem. This table though has been a problem child from the get go....
