As for working offline, you could store the JSON String to your SDCard or phone's internal storage and read it from there.
You can apply a query to your FeatureLayer. Check out ArcGISFeatureLayer.queryFeatures(); in the API help.Here's a sample. Obviously you'll have to modify the where clause: try { fLayer = new ArcGISFeatureLayer(layerDefinition, fs, options); Query q = new Query(); q.setWhere("MYVAL = 'xyz'"); q.setReturnGeometry(true); q.setOutFields(fLayer.getOutFields()); fLayer.queryFeatures(q, null); map.addLayer(fLayer); Toast.makeText(FeatureCollection.this, "Flicker feed contents added to feature layer", Toast.LENGTH_SHORT).show(); } catch (Exception e) { // TODO Auto-generated catch block e.printStackTrace(); }
Check the LogCat. I am getting an Unrecognized character escape ''' exception being thrown. You might have to pick thru the RSS feed from Flickr as it may have changed.
10-22 17:10:52.335: D/dalvikvm(19593): GC_CONCURRENT freed 225K, 5% free 7005K/7367K, paused 2ms+6ms 10-22 17:10:52.764: D/dalvikvm(19593): GC_FOR_ALLOC freed 292K, 8% free 7060K/7623K, paused 19ms 10-22 17:10:54.210: D/Test(19593): fiedName is title 10-22 17:10:54.210: D/Test(19593): fiedName is link 10-22 17:10:54.217: D/Test(19593): fiedName is description 10-22 17:10:54.217: D/Test(19593): fiedName is modified 10-22 17:10:54.217: D/Test(19593): fiedName is generator 10-22 17:10:54.217: D/Test(19593): fiedName is items 10-22 17:10:54.257: W/System.err(19593): org.codehaus.jackson.JsonParseException: Unrecognized character escape ''' (code 39) 10-22 17:10:54.257: W/System.err(19593): at [Source: java.io.StringReader@412bf070; line: 87, column: 23] 10-22 17:10:54.257: W/System.err(19593): at org.codehaus.jackson.JsonParser._constructError(JsonParser.java:1432) 10-22 17:10:54.264: W/System.err(19593): at org.codehaus.jackson.impl.JsonParserMinimalBase._reportError(JsonParserMinimalBase.java:521) 10-22 17:10:54.264: W/System.err(19593): at org.codehaus.jackson.impl.JsonParserMinimalBase._handleUnrecognizedCharacterEscape(JsonParserMinimalBase.java:496) 10-22 17:10:54.264: W/System.err(19593): at org.codehaus.jackson.impl.ReaderBasedParser._decodeEscaped(ReaderBasedParser.java:1606) 10-22 17:10:54.264: W/System.err(19593): at org.codehaus.jackson.impl.ReaderBasedParser._skipString(ReaderBasedParser.java:1406) 10-22 17:10:54.264: W/System.err(19593): at org.codehaus.jackson.impl.ReaderBasedParser.nextToken(ReaderBasedParser.java:366) 10-22 17:10:54.272: W/System.err(19593): at com.esri.arcgis.android.samples.featurecollection.FeatureCollection.generateGraphics(FeatureCollection.java:181) 10-22 17:10:54.272: W/System.err(19593): at com.esri.arcgis.android.samples.featurecollection.FeatureCollection.access$1(FeatureCollection.java:163) 10-22 17:10:54.272: W/System.err(19593): at com.esri.arcgis.android.samples.featurecollection.FeatureCollection$1.onStatusChanged(FeatureCollection.java:95) 10-22 17:10:54.272: W/System.err(19593): at com.esri.android.map.c.b(Unknown Source) 10-22 17:10:54.272: W/System.err(19593): at com.esri.android.map.c.handleMessage(Unknown Source) 10-22 17:10:54.272: W/System.err(19593): at android.os.Handler.dispatchMessage(Handler.java:95) 10-22 17:10:54.280: W/System.err(19593): at android.os.Looper.loop(Looper.java:137) 10-22 17:10:54.280: W/System.err(19593): at android.app.ActivityThread.main(ActivityThread.java:4514) 10-22 17:10:54.280: W/System.err(19593): at java.lang.reflect.Method.invokeNative(Native Method) 10-22 17:10:54.280: W/System.err(19593): at java.lang.reflect.Method.invoke(Method.java:511) 10-22 17:10:54.280: W/System.err(19593): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:790) 10-22 17:10:54.280: W/System.err(19593): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557) 10-22 17:10:54.288: W/System.err(19593): at dalvik.system.NativeStart.main(Native Method) 10-22 17:10:57.733: D/dalvikvm(19593): GC_CONCURRENT freed 428K, 9% free 7070K/7687K, paused 2ms+2ms 10-22 17:10:57.764: E/ArcGIS(19593): Failed to initialize the ArcGISFeatureLayer. 10-22 17:10:57.764: E/ArcGIS(19593): java.lang.reflect.InvocationTargetException 10-22 17:10:57.764: E/ArcGIS(19593): at java.lang.reflect.Constructor.constructNative(Native Method) 10-22 17:10:57.764: E/ArcGIS(19593): at java.lang.reflect.Constructor.newInstance(Constructor.java:417) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.internal.util.b.e(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.internal.c.a.a(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.internal.c.f.a(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.internal.c.f.a(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.android.map.ags.ArcGISFeatureLayer.<init>(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.android.map.ags.ArcGISFeatureLayer.<init>(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.arcgis.android.samples.featurecollection.FeatureCollection$1.onStatusChanged(FeatureCollection.java:104) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.android.map.c.b(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.android.map.c.handleMessage(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at android.os.Handler.dispatchMessage(Handler.java:95) 10-22 17:10:57.764: E/ArcGIS(19593): at android.os.Looper.loop(Looper.java:137) 10-22 17:10:57.764: E/ArcGIS(19593): at android.app.ActivityThread.main(ActivityThread.java:4514) 10-22 17:10:57.764: E/ArcGIS(19593): at java.lang.reflect.Method.invokeNative(Native Method) 10-22 17:10:57.764: E/ArcGIS(19593): at java.lang.reflect.Method.invoke(Method.java:511) 10-22 17:10:57.764: E/ArcGIS(19593): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:790) 10-22 17:10:57.764: E/ArcGIS(19593): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:557) 10-22 17:10:57.764: E/ArcGIS(19593): at dalvik.system.NativeStart.main(Native Method) 10-22 17:10:57.764: E/ArcGIS(19593): Caused by: java.io.FileNotFoundException: http://help.arcgis.com/en/webapi/javascript/arcgis/demos/images/flickr.png 10-22 17:10:57.764: E/ArcGIS(19593): at libcore.net.http.HttpURLConnectionImpl.getInputStream(HttpURLConnectionImpl.java:177) 10-22 17:10:57.764: E/ArcGIS(19593): at java.net.URL.openStream(URL.java:462) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.symbol.PictureMarkerSymbol.a(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.symbol.PictureMarkerSymbol.<init>(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.android.a.a.a(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): at com.esri.core.renderer.SimpleRenderer.<init>(Unknown Source) 10-22 17:10:57.764: E/ArcGIS(19593): ... 19 more
I'm a little desperate traying to load a featurecollection, I've launched the sample on my device (Samsung Galaxy Tab 7.0 - Android 4.0 IceCream Sandwich) and apparently it works, but it don't show graphics, just can see the Base Map.In other idea order, i would like to work offline, don't know if I can save the featurecollection in the device and then work offline.
