Sde Owned Schema:This parameter is only active for SQL Server. Check Sde Owned Schema if you want the geodatabase to be created in the schema of a user named sde. If unchecked, you must be logged in to the SQL Server instance as a user who is dbo in the SQL Server instance, and the geodatabase will be created in the dbo schema in the database.
