Hello all, please can anyone tell me the solution ?
My ArcGIS server is in ip : 192.168.224.16 and I have created users in server thus ppls can login to the server from their PC's. For example I want to login from 192.168.224.15 IP. But I cannot.
Check the firewall on the server. Port 6080 must be accessible from the remote host.
- V
You may have other security in place preventing this also.
Securing your ArcGIS Server site—Documentation (10.3 and 10.3.1) | ArcGIS for Server
This tells how to secure it, but sometimes putting these items in place can prevent the ability to log in from other machines or thru IP. for example,
- do you have SSL installed. in that case, you may need
https://<you machine name>:6443/arcgis/manager/
- Do you have admin permisisons?
Thank you all. I have done it. I closed the firewall for 6080 port and now i can access the arcgis server manager from other PC's of my network.
Remember to mark any results that were helpful, and one as answering your question, or "assumed answered" if none answered your question but it is resolved, so others known the problem has been solved.
I think you mean you opened a port. When a firewall is installed, most ports are closed. The term of art is "poke a hole in the firewall" to enable communication, and it does have sinister connotations, since too many holes would let a fire through.
Be sure to always document whatever ports you enable, and to keep their scope appropriately limited.
Hello Vince, thank you, yes I opened the port 6080.
Regards
Muqit
