The link to the bug report does not work - can you check and re-post? Thanks!
I will install 10.1 today and try synchronization. Let you know how it goes.
Sravan
Can you please try to synchronize the replica using Desktop 10.1/10.0 and check whether the issue is reproducible.
The Bug has been fixed at 10.3 as per the information provided in below link:
NIM094669 - Synchronizing replica after deleting 1000 or more ..
Any resolution on this issue? I am getting the same error during Synchronization process.
Hi Marcelo,Have you recently made any changes to the schema of the layers in the database OR have you added any layers to either of the database?Have you checked the replica manager and validated the schema, you may also want to try and manually export data changes messages and import messages...You may want to include the version of ArcGIS(9.3, 10, 10.1, 10.2, SP1, SP2) you are using and the replica type (One way, Two way, etc.)Sol
