# Import modules import arcgisscripting import datetime # Create geoprocessor object gp = arcgisscripting.create(9.3) # Get Parameters catchments = gp.GetParameterAsText(0) # Feature Class idField = gp.GetParameterAsText(1) # Field streams = gp.GetParameterAsText(2) # Feature Class bufferDistance = int(gp.GetParameterAsText(3)) # Long landCover = gp.GetParameterAsText(4) # Feature Class outFolder = gp.GetParameterAsText (5) # Workspace tempWorkspace = gp.GetParameterAsText (6) # Workspace gp.overwriteoutput = True gp.Workspace = tempWorkspace gp.ScratchWorkspace = tempWorkspace # Set-up environment variables desc = gp.describe (catchments) xmin = desc.extent.xmin ymin = desc.extent.ymin xmax = desc.extent.xmax ymax = desc.extent.ymax gp.XYDomain = str(xmin - (bufferDistance*2)) + " " + str(ymin - (bufferDistance*2)) + " " + str(xmax + (bufferDistance*2)) + " " + str(ymax + (bufferDistance*2)) # Create names for geoprocessing interim files based on the type of workspace selected wsDesc = gp.Describe(tempWorkspace) wsType = wsDesc.WorkspaceType # If the workspace is a folder if wsType == "FileSystem": ## Interim files must have the ".shp" extension streamsd = "streamsd.shp" catchStrm = "CatchStrm.shp" catchStrmBuff = "CatchStrmBuff.shp" catchStrmBuffDiss = "CatchStrmBuffDiss.shp" catchStrmBuffInt = "CatchStrmBuffInt.shp" selection = "Selection.shp" selectionDiss = "SelectionDiss.shp" selectionDissInt = "SelectionDissInt.shp" tableName = "Rip" + str(bufferDistance) + ".shp" appendTable = "AppendMe.dbf" # If the workspace is a geodatabase elif wsType == "LocalDatabase": ## Interim files do not require an extension streamsd = "streamsd" catchStrm = "CatchStrm" catchStrmBuff = "CatchStrmBuff" catchStrmBuffDiss = "CatchStrmBuffDiss" catchStrmBuffInt = "CatchStrmBuffInt" selection = "Selection" selectionDiss = "SelectionDiss" selectionDissInt = "SelectionDissInt" tableName = "Rip" + str(bufferDistance) appendTable = "AppendMe" # Dissolve streams not allowing multipart to reduce the number of features to be buffered gp.Dissolve_management (streams, streamsd, "", "", "SINGLE_PART", "") # Count the total number of catchments resultCatchments = gp.GetCount_management(catchments) countCatchments = int(resultCatchments.GetOutput(0)) # Make a feature layer from the catchments gp.MakeFeatureLayer_management (catchments, "CatchLayer") # Create a search cursor to loop through the catchments 300 at a time rows = gp.SearchCursor (catchments) row = rows.next() x = 0 list = [] while x < countCatchments: ## If there are fewer than 300 features remaining if countCatchments - x <300: remaining = countCatchments - x for i in range (0,remaining,1): objectID = row.getvalue ("ObjectID") row = rows.next() x = x+1 ## Otherwise else: for i in range (0,300,1): objectID = row.getvalue("ObjectID") row = rows.next() x = x+1 ## Add the 300th, or last, ObjectID to the List list.append (objectID) # Get the ObjectIDs from the list and perform selections and geoprocessing # How many items are in the list? items = len(list) for i in range (0, items, 1): ## If this is the first item on the list if i == 0: query = '"OBJECTID" <= ' + str(list) lastitem = list ## Otherwise else: query = '"OBJECTID" > ' + str(lastitem) + ' AND "OBJECTID" <= ' + str(list) lastitem = list gp.SelectLayerbyAttribute_management("CatchLayer", "NEW_SELECTION", query) ## Get the number of catchments selected resultSelCatch = gp.GetCount_management("CatchLayer") countSelCatch = int(resultSelCatch.GetOutput(0)) ## Intersect catchments and streams gp.Intersect_analysis ("CatchLayer;" + streamsd, catchStrm, "ALL", "", "INPUT") resultIntersect = gp.GetCount_management(catchStrm) countIntersect = int(resultIntersect.GetOutput(0)) ## Buffer intersected catchments and streams gp.RepairGeometry_management (catchStrm) gp.Buffer_analysis (catchStrm, catchStrmBuff, bufferDistance, "FULL", "ROUND", "NONE") ## Dissolve the buffered streams... process may fail if this is done as part of the buffer operation gp.Dissolve_management (catchStrmBuff, catchStrmBuffDiss, idField, "", "MULTI_PART", "") ## Intersect catchments and buffer gp.Intersect_analysis (catchments + ";" + catchStrmBuffDiss, catchStrmBuffInt, "ALL", "", "INPUT") ## Select features where buffer ID and catchment ID are the same gp.Select_analysis (catchStrmBuffInt, selection, '"'+ idField + '"="' + idField + '_1"') ## Dissolve selected features based on ID, allowing multipart gp.Dissolve_management (selection, selectionDiss, idField, "", "MULTI_PART", "") ## Intersect dissolved features and land cover gp.Intersect_analysis (selectionDiss + ";" + landCover, selectionDissInt, "ALL", "", "INPUT") ## Dissolve intersected features based on ID and land cover type, allowing multipart gp.Dissolve_management (selectionDissInt, tableName, idField + "; SCO_Class", "", "MULTI_PART", "") ## Add field (Area) gp.AddField_Management (tableName, "Area", "DOUBLE", "#", "#", "#", "", "#", "#", "") ## Calculate area field gp.CalculateField_management (tableName, "Area", "!" + gp.describe(tableName).shapefieldname + ".AREA@SQUAREMETERS!", "PYTHON_9.3", "") ## If this is the first set if i == 0: ### Export attribute table gp.TableToDBASE_conversion (tableName, outFolder) ## Otherwise else: ### Export the attribute table and append it onto the existing one gp.MakeTableView_management (tableName, "RipView") gp.CopyRows_management ("RipView", appendTable) gp.Append_management (appendTable, outFolder + "\Rip" + str(bufferDistance) + ".dbf", "NO_TEST") # Delete the Temporary Files gp.Delete_management (catchStrm) gp.Delete_management (catchStrmBuff) gp.Delete_management (catchStrmBuffInt) gp.Delete_management (tableName) gp.Delete_management (selection) gp.Delete_management (selectionDiss) #gp.Delete_management (selectionDissInt) gp.Delete_management (streamsd) gp.Delete_management (catchStrmBuffDiss) gp.Delete_management (appendTable)
don't have 9.3 but could you make Management in that line lower case, I can't remember if 9.3 is case-sensitive or not
I've found using functions solves a lot of ghost schema locking issues I've had.
you could try to throw a Delete_management (see help for syntax) into the mix.
def AddField (fc): "Adds a field to a feature class, hopefully removes any schema locking errors" gp.AddField_management (fc, "Area", "DOUBLE", "#", "#", "#", "", "#", "#", "") .... ## Add field (Area) #gp.AddField_management (tableName, "Area", "DOUBLE", "#", "#", "#", "", "#", "#", "") AddField(tableName)
gp.Exists(tableName)
# Define any functions necessary to avoid schema locks ## Create a feature layer from catchments def MakeFL (catch): "Makes a feature layer from the input... hopefully a schema lock will be available for this layer" gp.MakeFeatureLayer_management (catch, "CatchLayer")
# Make a feature layer from the catchments #gp.MakeFeatureLayer_management (catchments, "CatchLayer") MakeFL (catchments) exists = gp.exists ("CatchLayer") print "Was 'CatchLayer' created? " + str(exists) lockTest = gp.TestSchemaLock ("CatchLayer") print "A schema lock is available for 'CatchLayer' immediately afer it is created: " + str(lockTest)
Could you please let me know if I have implemented your suggestions correctly, and if I have, do you have any others?? 😛Thank-you!
del row del rows
lockTest = gp.TestSchemaLock (selectionDissInt) if lockTest: ## Dissolve intersected features based on ID and land cover type, allowing multipart gp.Dissolve_management (selectionDissInt, tableName, idField + "; SCO_Class", "", "MULTI_PART", "") # <---- Fail print "dissolved intersected features based on ID and land cover type, allowing multipart" else: print "unable to get schema lock on selectionDissInt"
