Jessica,
You should be able to resolve by installing the latest patch for BA10.2.2 as it addresses a bug specific to this issue. URL is below.
Esri Business Analyst 10.2.2 General Patch 3 | Samples and Utilities
Regards,
Jason R.
Hi Jason,
The instructions you gave above I used a year ago when we upgraded to 10.1 with 2012 data, and it worked perfectly. It is a year later, and I need to do the same thing again for the our current upgrade (10.2.2, 2014 Business Analyst data). I have my standard geography (block groups for the US) ready, however, I can no longer find the Consumer Expenditure data under the variables when I use the append data tool under favorites on the Business Analyst toolbar. With no luck, I also tried to create a custom BDS layer and could not find the data there either.
I run reports using the Consumer Expenditure data, so I know the install is correct and everything is properly licensed. My only option to map this data at this point is to use the esri.bg.bds layer as my trade area, run a report with the particular CEX variables I need using the ID as my store ID and output as excel, then join the spreadsheet back to the esri.bg.bds layer to create a thematic map.
Please let me know if there is something I am missing, or if this data is no longer accessible for mapping other than my work around. Thank you for your help!
Jessica
Thanks Jason. I was afraid of that. Since they are no longer included in the block group layer, I guess I will have to create a layer with the CEX variables to use as a sales potential layer for when I want to run the Huff model computation.
I was wondering the best way to map the consumer spending variables. In previous version of Business Analyst, the consumer spending variables were fields in the attribute tables for the Demographic Layers (BDS) -- block groups, tracts, counties, states, etc. I went to the layer properties for the States layer and want to create a map of Total Consumer Expenditures by state but the CEX variables are not part of the attribute table. Any suggestions or did I mess something up in the installation as the reason why the variables are not showing up?Thanks!Paul
