We are facing problem that, during the conversion from (.shxe) format to GDB, points are not converting properly. While converting, lines to are converting to data files but points are not converting to data file.
Hi Kamal
Please describe the steps you follow for exporting the map, including the file type and settings. Please also provide the Esri Production Mapping version and build number.
To find the Esri Production Mapping version:
Thanks, Bo
Dear Bo,
Thanks for your post. Please see below answers of your questions:
Are you using ArcMap or ArcGIS Pro? ArcMap v6.0
What is the Esri Production Mapping version and build number? Please see the attached image below.
What tool are you using for the conversion? Map export
Also, regarding the SHXE file extension, it sounds like it might be an AutoCAD Compiled Shape File (SHX). If so, have you tried converting to SHP before working with this data? YES
Thanks for your question. I will need a little more information in order to assist with your issue.
Are you using ArcMap or ArcGIS Pro? What version?
Also, I am not familiar with the SHXE file extension, but it sounds like it might be an AutoCAD Compiled Shape File (SHX). If so, have you tried converting to SHP before working with this data?
